My Paslode nail guns will not shoot even after I cleaned it according to instruction. The battery is charged and the cartrige is new.
Piston is probably jammed
This happens sometimes try holding it up against a board with the trigger depressed and then inset the battery.
The goal is to try to force the firing sequence to get the piston back to the right position with corded units this is simply done by attaching the air hose with the trigger pulled this causes air to rush into the gun chamber pushing the piston back and firing a nail out.
The cause of this is a misfire or jammed nail that stopped the piston in the wrong location so air will not build in the chamber correctly.
Hope that helps
