Sounds like it is a sleep mode problem. Have you tried to re-set it completely? It basically just turns it off and re-boots it.
1. Press and hold down the circular "Home" key beneath the display while simultaneously pressing the silver "Sleep/Wake" button on the top right edge of the unit.
2. Hold the two buttons down for approximately ten seconds. Ignore any messages or images that appear on the screen of your iPod touch and continue holding until the Apple logo appears.
This should reset it like you just turned it off and on again.
SOURCE: white screen on ipod touch
http://www.ziphone.org/
Use the Ziphone ipod touch and iphone jailbreak GUI to put the ipod in recovery mode. Then restore it using iTunes.
i had the same problem with 'band'
SOURCE: my ipod touch has a white screen and it won't let me do anything
if you dont mind losing your music try a shift restore on the firmware, you can download official firmware just put go to your itunes and look at you ipod and what the newest fw out is and then google it download it, and go to itunes and on the restore tab hold down shift and click on restore this will allow you to restore from current firmware and hopefully the reset will fix the problem
SOURCE: I am still looking for an iPod touch 8GB manual to
I found some different manuals for the ipod touch at apple.com. See if this one will help you out at all.
http://manuals.info.apple.com/en_US/iPod_touch_2.0_User_Guide.pdf
SOURCE: delete photos off ipod touch 8GB?
I published a step by step solution that will allow you to do this, from within iTunes. This will work for you, and is easy to follow.
http://jawzblog.blogspot.com/2009/08/removing-photos-from-ipod-via-itunes_03.html
SOURCE: i forgot my password to my 8gb ipod touch
Hello.
Welcome to Fixya Community.
You need to restore it with iTunes, but you can't restore an iPod While its Locked With a password, well in order to Force it to Restore you shud put it on Recovery Mode.
Hold down the power and home keys down for about 10 seconds each while
plugged into iTunes. When the screen goes black, release the power
button but keep holding the home key until itunes says. We have
detected an itouch in recovery mode.
From there you can restore as normal via iTunes.
and that will reset you configuration including Your Password.
Thank you For Using Fixya.
Good Luck.
