Same thing happened on my blackberry bold, so i contacted my service provider(vodafone) and heres what they told me to do.
1.go into menu.
2.click on options.
3.choose mobile network.
4.then mobile selection mode.
5.change from automatic to manual.
6.let it search for a network.
7.select a different service provider from your own.
8.when its done reselect your service provider.
9.change from manual back to automatic.
That should sort it. Hope i helped.
Were you ever able to send them in the past?
make sure your sms service center number is correct.
oull the battery out while the phone is on see hwat happens.
if none of these work connect the phone t the computer using desktop manager and selec application loader and then update software.
SOURCE: new ringtone for my text messages!
select options --> select profiles --> select advanced --> select SMS --> menu --> change options --> select the desired ringtone
SOURCE: Blackberry Pearl automatically deleting messages
I have the same problem! I can see a text be sent to me but erases before i can even look at it!
SOURCE: how do i change my sms text message ringtone on my
You need a notification profile.
1. Go to Profiles > Advanced.
2. Highlight the active profile (typically called Normal), press the Menu key, then choose Edit.
3. Scroll down to SMS Text and press the trackball.
You can then change the tone there. Now this tone or sound will be the
same thing you hear when you get a voice message. The Voice Message
sound is always the same as the SMS Text sound.
how long has it been since they stopped or have they never worked? more info please the more disctiptive the better! can you send text? maybe a fire wall setting check those out in the options menu.
