Kenmore model 56539 side-by-side refrigerator defrost heater does not cycle on to clear coil of ice buildup. Have to periodically remove coil cover and manually defrost the coil.
You didn't send the full model number,starts with 110.or similar,you have a defrost problem,it could be a couple of things so you need to read out some parts with a meter,you could have a bad defrost thermostat the timer or adaptive defrost board depending on model number,bad heater,if it has a timer you need to advance it by turning the middle with a screw driver until you hear a click and the fan shuts off in the freezer,now you have it in defrost,see if the heater is on,if it is you have abad timer,if it didn't come on check the t stat,if it has plug in connectors on the wires disconnect the t stat and plug the wire derectly to the heater or if you have to cut the wires cut them and bypass the thermostat,if the heater comes on then you know you have a bad t stat,also pull the wires off the heater and check the heater,if the heater is bad it's a good idea to change out the t stat anyway,if it has an adaptive defrost board check the tech sheet that should be behind or on the bottom kick plate,remove it and look it will tell you how to put the fridge into defrost,i think you push in the both door switches 5 times at the same time,if it doesn't go into defrost could be the board,you'll have to still read out the heater with a meter,also if you read out the thermostat it has to be cold,if it warms up it will read open but it still could be good,if you need any more help with this let me know and send model number so i can help better
Testimonial: "Would have helped to know where these controls are located. The refiderator is located in a close area and hard to move. The model begins with 106."
that's why i asked for the full model number,if it starts with 106.there should be 8 more numbers,i could have looked up your machine and told you if you had a timer in there or not,the heater and t stat are behind the freezer panel that you took off to melt out the coil,if it has a timer it could be behind the bottom kick panel under the doors or in the fresh food section,if it has a board that could be in the same spot,hope this helps you,you also have to melt out all the ice again too
