Buy a HHD docking station that you can drop your SATA hard disk drive into. you plug the Docking Station into an avalable usb port.
If you can't use the hard disk with this docking station the disk is bad.
This works about 99% of the time, great method for using or recovering old files (pictures, files) off of used hard drives.
Amazon com Thermaltake BlacX N0028USU HDD Docking Station Electronics
SOURCE: Appears on Device Manager but not on My Computer
you can still use partition table disk doctor to restore your old partitons and the dat a will be seen back automatically like magic..
SOURCE: Cannot see WD 120 GB in my Computer
Sounds like the USB interface is working, but the physical drive is not. Remove the drive from it's external case, and try a different hard drive. If that works, your drive is the problem. If it still doesn't work, the USB to IDE interface is the issue.
Try mounting the original IDE drive internally, and see if you can read it there. If not, you'll need to send it to a data recovery center.
SOURCE: LaCie 500GB was formatted for MAC and given for
You will need to format the device for Windows use. If you can see the device in My Computer, right click it and select format. if you can't see it in My Computer, you will need to use a boot tool such as Gparted: http://gparted.sourceforge.net/download.php
Download the .iso file and burn it as an image to a cd, then boot from the CD at startup. It should detect the 500 Gb drive and allow you to format it to NTFS. Then Windows will recognize it.
