It is important to state the make and model of a printer to get better help. You may have a canon and some of the canons get a stuck laser shutter which will cause blank copies.
I am assuming you have emptied the old waste toner "box" and not replaced it with a new box. This is not a problem, just clarifying. If this is the case then you have toner packed into the sensor block which is telling the machine that the waste toner box is still full. Just look behind the waste toner box and look for a little set of wires. They lead to a small black sensor. Now look at the waste toner box where it mates up with the sensor. You will see a small square box area on the waste toner bottle. The sensor looks thru this block and if it is blocked with toner it will tell the machine the box is full. Just tap on the little block and make sure there is no toner in it and re-install the waste toner box and the indicator should go away.
Good Luck and Thank You for using Fixya.
Its a magnetic powder that combines with toner and trough magnetic roller is transfered on drum. Without it you cant make copies or prints. I pressume because of blank copies that you trying to install copier.In package there must be developer.
1-The unit that the toner goes in is probably not filling up with the toner or the unit has a problem. open copier take out drum unit and look at the unit where the toner goes into, there is a black roller with toner on it, is there a spot that seems to be missing toner? If yes it will require a tech too complicated to do for a non- tech.
2- If not, look at the black roller on the bottom of the drum unit is there toner there? clean and try.
