Your CF-27 performs a thermal shutdown protection the moment it detected a hardware problem. Make sure that the vent holes
are not blowing off too much heat. If it does, one or more fans inside went down.
Also, does it shutdown by itself even if plugged into a power adapter? And since you have a bad battery, it time that you change them for a new one; constant shutdown of the laptop would further damage the system.
Do you use it on batteries?
Unfortunately, for almost every laptop manufactured, most of them run out of battery power as time goes on.
This may happen after one or tow years, to the point that, you may only run it on battery for a few minutes.
I use to experience the same problem with my laptop, after one year of using it, the stopped working well and the laptop would only run for 10 minutes on battery.
If possible, you can try to replace the battery with a new one, that should solve your problem.
Thank you for using Fixya,
Kenneth
1. Check the batteries. 2. After remove the battery Turn on the system by power adaptor And see what's going after a 30 min. 3. run by battery only and watch 30 min. if all of these showing the same result, then 4. remove the RAM & CPU then visit a service center for checking its working or not.
Changes of damage is RAM, Processor, & Motherboard power supply system.(SMPS). Thanks & hope you will short out your problems. Waiting for your feedback.
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
my cf-27 shuts down after 5min. or sometimes 30min. im pluged in to ac because my batt. are to weak to operate system
my cf-27 just shuts down after 5min. or maybe after 30 min.I power up,and it randomly shuts down.I always use a.c. power because batteries are to weak to use. i would really appriciate any help.Steve
my cf-27 lap top keeps shutting down. It might run for 5,15,sometimes45 min.before it shuts down. I run it on a,c. power because my batteries are bad. thanks for your assistance,steve.
