I have my printer hooked to an Imac. It will NOT print automatically. If I have a 10 page document to print, I have to hit "continue" after each page is printed because it says "MF Feed Letter" on the display and will stop printing unless I manually hit the "continue" button after each and every page.
Go to the printer setting's and make sure that the printer paper feed are not set into a Manual feed.
Thanks,
Good to hear that from you, and you did a good job out there..
Regards,
pinc
Right click on the printer icon.
1. go to control panel.
2. select printer/faxes
there you will see the printer installed, right click to that icon and uncheck if its selected the make the printer offline.
Enjoy
Because you have to select the printer you will use. There's 1 default printer and you have 2 installed on your system, you must call which printer you will use if it's not set on default.
HP 1008 Laser jet printer
HP 1505 Laser jet printer
HP 2035 high resolution printer
good luck
THANK YOU!!! I checked this before, but this time I hit "enter" to save it and it is now working like a charm! Thanks for such a quick response. I now can print without having to sit with one finger on the "continue" button!!! Wahoo!
Oh gosh...now it won't go on line even though it says it is. This happened when I turned it off and then turned it back on again. The "on line" light is lit, but then I get a message saying it's "off line" when I try to print and now it won't print anything.
Any idea?
Well....I turned it off and then turned it back on and now it shows the "on line" light is lit, but when I try to print, it says the printer is "off line". Any ideas???
Thanks. That worked for one time. I had my printer settings to "select the last one used". I changed it to make the laserjet printer the default and it worked once. It seems it will work, but I must reboot my computer first before it will print anything. Then it works fine???? Luckily I am on an Imac and it doesn't take forever to reboot like windows does.
I am also using paralells desktop and have windows loaded on the same Imac. Do you think that could have anything to do with my printer problem?
When I run Windows on it, I have to turn my other printer off and then back on before it will print from windows, and then it prints just fine.
I am having printer problems with two printers in two different os, but the problems are different.
Any ideas?
It keeps printing what looks like a stats sheet. It also only does this when I push the continue button. It wont print when I push print from any programs.
