SOURCE: Control Panel Issue
sounds like a contorl board issue it might be going out i suggest get a repair guy out to fix it u can use our directory to find someone near u
SOURCE: after cleaning, display flashes F7 and it
HI. This code is referring to a failed function key(s). These key are located on the control board. Replace the touch pad or if touch pad is part of the clock(main control board), replace the clock
(ERC).
F-7 Function key(s) shorted or stuck
SOURCE: i went to change the
This link will take you to your part drawings and wiring schematics.
Click on the link http://www.searspartsdirect.com/partsdirect/part-model/Jenn-air-Parts/Range-Parts/Model-SCE30600W/1266/0124160?searchedModel=SCE30600&blt=
Looking at the schematics and the info you have provided the issue you are having is in the control panel Having the control take some of your commandsand not others,demonstartes the control is bad.
In most cases this is the most common reactions of a control board. The control will not very often completely go bad but just some of the options.
The control board is made of of circuits and relays. Each relay is responsible for different functions. In most cases the relay is what goes bad.
This link is the part that you need. http://www.repairclinic.com/Shop-For-Parts?s=t-%2071001799-%3d%3d They have a no questions asked return policy for 1 year.
Any other questions or concerns please post.
Keith
SOURCE: top burners will not ignite
What is the model number of your range? It should be posted in the oven.
Richard
Roth
The
FixYa Team
