Question about Logitech Harmony 880 LCD Remote Control
I have a logitech remote for my tv, just bought a wii game. Do i need to program it into my remote as i cannot get the wii to work?
    Novelist:
  • 76 Answers
Because the Wii does not have IR receivers, it is not directly compatible with the Harmony remotes. However, you can still create a "Play Wii" activity that will turn on your other devices that are needed for the activity and set them to the correct inputs. So, for example, you would still need to turn the Wii on manually, but you the "Play Wii" activity would turn the TV on, set the correct input for the Wii and activate your sound system (if separate from the TV). Hope this helps!
Posted on Feb 26, 2010
Anonymous
SOURCE:
Bought a new will remote but it won't work.
Go into the Wii channel and go to settings then look for calibrated remote. Make sure the new wiimote is on. Set the Wii controller on a flat surface and press callibrate. The wiimote will be ready to use .have fun.
Hope this helps.
Apr 29, 2014 | Nintendo Wii Video Game Consoles & Games
Setting up my Wii system using Harmony 670 Remote
I just thought you should know the Harmony Remote is only able to control any device that uses infrared control. Unfortunately the Wii console uses Bluetooth technology which means the Harmony Remote would not be able to control it.
Hope this helps you!
-Kennedy
Feb 23, 2010 | Logitech Harmony 670 LCD Remote Control
We just bought new wee remote and it will not
Have you checked the remote sensor strip that you mount on the TV is there? Is it connected to the WII console?
Dec 28, 2009 | Nintendo Wii Console
I can not get my Harmay 520 to program to my tv or vcr,dvd and wii game
The Logitech Harmony 520 remote control is programmed through the Harmony Setup Software you can download from here.
Once installed, you will simply run the software, and select the devices you would like to control from menus. The software finds the right codes for you and loads them into your remote control.
I hope that helps.
_____________________________________________
Harmony 520 Manual Download
Logitech Harmony Firmware Update
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
Oct 01, 2009 | Logitech Harmony 520 LCD Remote Control
Compatible TVs
I can help you with your Logitech Harmony 550 remote control.
The Logitech Harmony 550 remote control is programmed through the
Harmony Windows Setup Software.
Once installed, you will simply run the program and select the devices you would like to control from menus. The software finds the right codes for you and loads them into your remote control.
I hope that helps.
Harmony 550 Manual Download
Harmony MAC Software Download
Jun 06, 2009 | Logitech Harmony 550 Remote Advanced...
Another problem with second wii remote for mario cart
press the red button at the back of the remote and then open the cover at the front of the wii and press the red button
Mar 29, 2009 | Nintendo Mario Kart (Wii) for Wii
Trying to hook up wii. Have a Hitachi plasma tv, cable, and the Logitech Harmony 670 universal remote. All cables are attached, the box is on, but cannot access the program on the tv.Can you assist?
Depending on the type of inputs you have on your TV, you may need to order a component cable. The one that ships with the Wii is just a composite cable and some high-end TVs might not have the right connection for it. Fortunately, you can get this cable for less than $5 at monoprice.com. Good luck!
http://www.monoprice.com/products/product.asp?c_id=108&cp_id=10830&cs_id=1083001&p_id=3566&seq=1&format=2
Jan 03, 2009 | Nintendo Wii Console
New wii remote how to get started
Ok well first of all, you'r first remote is working fine right? Ok lets move on to the second remote. On the left of the wii there is a little hatch that you can open, in there there is the slot to insert a SD memory and there is a red button. Press the red button and wile that is hapenning grab the wiimote and pres 1 and 2 at the same time once. The lights on the remote should start flashing and it will be in sync all together.. And voila two wii remotes working fine,
-Alex
Nov 22, 2008 | Nintendo Wii Console
Denon avr3200-lost the remote-cannot program the surroun-where to buy?
Try looking here:www.logitech.com. I use the Harmony 880 to run all my electronic(tv, dvr, receiver, game systems) and love it. It is programed via USB over the computer. You find the remote to fit your needs and the Logitech website will program the remote.
Apr 28, 2008 | Televison & Video
Logitech Harmony 880 LCD Remote Control Logo
88 people viewed this question
Top Logitech Televison & Video Experts
ray gallant
scotteclipse
Level 1 Expert
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
