I need to know how to manually get to the option on the screen that allows you to run the self cleaning bleach cycle on electrolux laundry washing machine
? 0:47 https://www.youtube.com/watch?v=JNVPSVe_MV0
Mar 25, 2015 - Uploaded by Universal Appliance and Kitchen Center
Electrolux fresh clean feature is the perfect ingredient for cleaneroven, with 3 different levels of cleaning .
Feb 10, 2011 - So, I want to do a self clean cycle manually. ... wake up washer by pressing any button rotate cycle knob to handwash press start and then cancel. ... I am not sure my machine is operating on the clean cycle.
Hi friend, thank you for your inquiry!
I understand that you are receiving a "remove racks" message on your Electrolux range. The oven racks and supports must be removed before the self-clean will initiate or the control will not allow the self-clean to turn on. I hope this is helpful. -Matt
I understand that you are having trouble with your Electrolux Icon oven, model# E30SO75ESS, and running the self-clean cycle. I see that the lock button keeps flashing and that you have the racks and rack holders out. I suggest following the steps below to run your self-clean cycle:
1) Place the rack holders and the racks in your oven.
2) Reset your appliance, by shutting the power off at your homes circuit breaker, for 3-5 minutes.
3) Restore power.
4) Reset the clock, by pressing the "Clock" button then press the number "2". Enter in the time of day, and then press the "Clock" button again.
5) Start the self-clean cycle with the racks in your range. This is to make your oven recognize that the racks are in the oven.
6) Take the racks and rack holders out and start the self-clean cycle again.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your oven status has changed successfully.
I see that you are having trouble with your Electrolux range, model# E30DF74GPS, and getting it to go into the self-clean cycle. I would suggest giving it a hard reset. First make sure the racks are in. Next, cut the power at the circuit breaker and leave it off for 2-3 minutes. After the time has elapsed cut the power back on. Start the self-clean cycle with the racks inside the oven. We're trying to get the oven to recognize the racks are inside. Once it states the racks are in, cancel out and take the racks out. Now, with the racks out start the self-clean cycle again. If you are still receiving the red light blinking, I suggest contacting the manufacturer or your local authorized technician. Hope this has been helpful.
you could always put dishes needing washing in the washer and run cycle. The electric element will heat the water to 140 degrees and it will clean just fine.
The SteamClean option spot cleans the oven in 20 minutes and is recommended for cleaning light spills on the bottom of the oven cavity. When used routinely, the SteamClean option reduces the need for frequent self-clean cycle use. To use the SteamClean option, pour 12 ounces (1 1/2 cup) of water into the bottom of the oven cavity, close the oven door and push the SteamClean button. At the end of the cycle, consumers wipe out the bottom of the oven, easily removing oven soils. The steam cleaning option is eco-friendly and does not require frequent use of the self-clean cycle, which can create a strong odor. Read this in a post about the new whirlpool ranges
well may be too late now, but you need to removeth racks prior to cleaning, the heat will discolor and make them hard to pull out.. as far as letting stand for a given time after cycle, the unit will automatically unlock when it has cooled to an acceptable level, in which case youll need only to wipe out the ashes with a damp cloth
Close the oven and the associate latch ( near the handle) then select the self cleaning option on the control.. Let it run thru its cycle.. when it is complete and cooled down enough.. the door latch will release and allow entry into the oven.. Hope that helps..
