Zanussi 23 in. ZDT6252 Built-in Dishwasher Logo
Posted on Feb 17, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My zanussi dishwasher won't drain,the water is sitting at the bottom of it as the kids opened it and a cycle wasn't finished and the water won't drain
Paul Carew
Level 3:
  • Zanussi Master 3,808 Answers
  • Posted on Feb 17, 2010
Paul Carew
Zanussi Master
Level 3:
Answers
3808
Questions
Helped
1299223
Points
10526
Hi blocked drain plug or pump is blocked
Zanussi diswasher ZDI6053N does not finish its cycle.It has to be turned off manually
Your dishwasher is a sophisticated device that registered most failures. The End of cycle LED flashes if there are alarms memorized. So, count how many times the End of cycle LED flashes.
For example:
One flash - i10, the problem with water intake
Two flashes - i20, a problem wit drain water
Three flashes - i30, activated anti-flooding device
..... and so on
Dado
Check float valve
pull out your bottom rack, in one of the bottom corners of your dishwasher there will be a circular plastic piece. it is probably stuck in the up position . Wiggle it around, it should sit loosely in place. It's a float, so when water fills in your washer, the float should raise up, when the water is draining, the float should lower with the water. That's why the float should be sitting loose in position.
Dishwasher won't drain all the way
A dishwasher will never drain all the way. It is designed to hold water as to not let the pump run dry and keeps the seals preserved.
1helpful
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 • Dishwashers
2helpful
Not cleaning fully - tablets left in bottom of unit - some of runners on bottom tray missing
Well first of all you can check the Water-inlet valve
Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need replace it.
After then you can check the Drain valve,  that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Please post comments if you need more help or information..............
Good Luck!!
Thanks
1helpful
Figidaire Dishwasher ModelFDB65BRAC1
I just had this problem with a zanussi dishwasher - I opened it this afternoon to find the bottom full of water - luckily not deep enough to flood my kitchen when I opened the door. I determined that the sink drain was clear (ran water, could hear it going down the drain outside), so the problem had to be in the dishwasher or drain hose. I poured just a little mr muscle sink & plughole unblocker in the bottom of the machine where the trap is, left it about 30 mins as per instructions, followed by a little boiled water - no difference. Scooped out the water, removed the filter (the big round bit, not just the trap that you pull out and empty) and scooped out till I could see what appears to be the out pipe. Thought what the heck and ran a rinse cycle - no dishes, no detergent and lower tray and arm thing removed for convenience. Water drained just fine, ran a second rinse cycle which got rid of the suds from the plughole unblocker. I now have an extremely clean and sparkling dishwasher and am about to run a load of dishes through it.
I hope that my post is helpful to you, I don't know if all the steps are necessary, it may have been a freak occurrence that would have gone away with a simple rinse cycle. It may of course be a problem with the pump on yours, I was hoping that wasn't the case on mine, and I had lots of old towels on hand in case water came out when I opened the door. But it's possible your machine has the same problem as mine and that this info works for you, I hope that is the case.
1helpful
Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
Top Zanussi Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
