Your battery may indeed be dead. Watches sometimes sit on store shelves for months and even years before you get them. If you have a stuck button it may be the light button and may have prematurely drained your battery. Either way a watchmaker would be able to determine the problem.
From your description the solar cell charges the battery and keeps it topped up. I think the rechargeable battery is the problem because when the screen goes blank the battery level drops to low and the LCD blanks out which would explain the intermittent operation of the watch. I think it is worth getting it checked out with an estimate.
mcdevito75 here, Double check the battery install, make sure all contacts are clean, with the watch open see all buttons depress and are hitting points on the movement. When done, presss the mode button and display should come up.
This sounds like a simple battery replacement. Depending on how low the battery is usually pressing the light button and the display goes dim or blank is a good indicator of this. Takes a CR1616 battery and be careful of the spring inside and make sure the seal is in the correct position. You will need to touch the AC button and the back of the battery with a pair tweezers for a couple of seconds to reset the watch. Put the case back on and set the watch thru the functions.
I have a Timex Digital Heart Rate Monitor 585 (product code T5C351F5)m, which has the same Short AC Pad and battery +ve message. There is an arrowhead pointing to the pad. It's a raised metal platform - a bit different to some of the Ironman's mentioned above. Here is a pic...
On the solar charge watches, they use a chargeable Lithium battery. It is NOT an off the shelf regular battery! It is best to send the watch to the factory service rep in your area for a battery change.
In many of these models the battery is using solder contacts to the circuit board. The person changing the battery will require the original spec battery, and be equiped to do surface type soldering.
When working on this watch, the factory service will change the seals and do a pressure water resistance test. The regular corner watch service store is not equiped to do this type of testing.
Normaly, the battery in solar watches should last more than 5 years. Some are going past 10 years!
