Hi , I am sorry to say that a rolex requires servicing on a regular basis . Every 3 - 5 years would be advised . If you consider that your watch is a delicate machine that may be working 24 hours a day for years then its not unreasonable that it needs servicing. Over time the fine oils dry and degrade , they need replacing , and parts can become damaged . As to cost , this is a skilled job . To service a rolex in the correct way requires not only skill ,but the correct tooling and equipment . Also the materials used must be genuine rolex , this is costly . Your accredited service centre will then provide a 2 year guarantee . All in all the price of $600.00 reflects the labour of a skilled man and his investment in gaining rolex status . There will be cheaper alternatives but beware as they will probably not be rolex trained and wont be using original materials .
Your calendar wheel is damaged. Unfortunately, it is illegal to own or work on a Rolex replica / fake Rolex as it is a trademark violation. I would suggest purchasing a genuine Rolex as a replacement, as there are generally no identifiable movements, and therefore no identifiable replacement parts for the movement in your timepiece.
Be aware, however, that all automatic and mechanical watches, such as Rolex, must be services regularly, every 3-5 years, for them to last and work properly. Thanks for the rating!
This model Rolex has been manufactured over multiple years, and it is not possible to date your watch based purely on is model number. However, it is possible to date most Rolexes based on their serial numbers, which can be found stamped between the lower lugs (i.e., the lugs below 6:00 on the watch dial). You will need to remove the band from these lugs to read the serial number.
Dating the watch case of a Rolex does not necessarily date the entire watch. It is possible that a movement from another watch was placed into a watch case that is younger or older than the the movement. Like Rolex watch cases, Rolex movements can also be dated by their serial numbers, if this is a concern you have about this particular watch.
This jeweler has put together a nice summary of when Rolex watch models were introduced and which serial numbers are associated with specific years of manufacture. Once you have found your serial number, this should help you date your watch. I have no connection (financial or otherwise) with this web site, but I found the information useful and presented in an easy to understand way.
It sounds like your Rolex isnt retaining its power.If worn for 8 hours a Rolex in good condition will hold power for 36 hours.
Rolex watches need regular servicing every 4-5 years so it may be due a service,the mainspring may be broken or the automatic windind may have a fault.
You need an expert Rolex watchmaker to advise you try www.rolexrepairs.co.uk they offer a free estimate and repairs are returned in 2-3 weeks depending on the work.
this watch will need a service from a rolex trained repairer wich wont be cheap 700 dollars min or 500uk pounds min..you could try tapping watch in palm of hand to see if a batton or luminous paint has come loose,then all it needs is movement taking out and blown clean inside case.any decent repairer can do this.sometimes the teeth on a wheel can wear in one place hence it always stops in same place.recomend service as best action,you never loose on a rolex...
i have a' rolex oyster perpertau superlativechronometerofically certified cosmograph' watch with an inscription on the back'winner rolex ad daytona 1992 24' is it a genuine rolex and if so what is it worth.thanks curtis and the date pointer came out from it place how to fix back?
take it somewhere to get it assembled with a warranty. If you lack the ability to reassemble the watch, why did you take it apart in the first place? Rolexs need cleaning and tune ups about every 10 years. My wife and I get ours done for $250 a watch and they come back looking like brand new.
