RTO Alternator/Battery Tester Logo
Posted on Feb 17, 2010
Hiace alternator replace
How to replace alternator for toyota hiace van 1998 2.4l carburetor
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1525
Points
Fit a new alternator to a toyota hiace
1helpful
What amps is it for an alternator for a 1988 Toyota Hiace commuter van?
That depends on how many accessories your van is equipped with. Items like the rear window defroster use a lot of amps. The more accessories, the more amps needed. Look up the number on the alternator to see what you presently have.
Valve clearance 1995 toyota hiace diesel van 3l
normally .010"hot inlet and .012" hot exhaust
How do i bleed clutch 2002 zx toyota hiace van
I have a 1995 hiace bus where do I bleed it from
1helpful
2answers
7helpful
2002 toyota hiace van front wiper reservoir refill point
I have the 1990 model and just so happened to stumble on its unusual location today as I was replacing the door hinges. On the passenger side open the door and look above the step, there should be a little plastic cap with the wiper icon on it. hope this helps!
2answers
Toyota HiAce 1988 alternator working no charge back to Battery
if it was me I would take the alternator off take it somewhere and have it tested because it sounds like it has a bad voltage regulator in it
Top RTO Measuring Tools & Sensors Experts
Arleth White
Level 1 Expert
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
