This could be more of a network issues. The first thing is take the battery out of yout phone. The second is put battery back in the phone. The thrid is clear any messages in yout send and out boxes. They both could be filled. Also you may want to do a reprtogramming of the poen. As to reset the phone. Good luck
dial *#7370# , then it will ask for security code then enter security code(nokia default security code is 12345).
The phone will restart.
Please take the backup of phone memory data(messages and contacts) before RESET the phone.
Try to to soft-reset your unit. (6 steps) 1. BUT Make sure you backup your phone memory to your memory card. Soft-reset deletes all data saved in your phone memory, including factory settings and pre-stored music, videos, etc. 2. Dial *#7370#. This would take at least 2 minutes. 3. Try sending messages to your own number. 4. If sending messages is working, you may now restore your backup of phone memory. 5. After restoring phone memory backup, try to send messages again. 6. If sending messages is not working again, chances are, your original phone memory is full and you should delete messages and contacts. You have to repeat soft-reset (steps 1-3). But your previous data should be accessed directly from your memory card so as not to directly save to your phone memory. ******ciao*****this works for me. took me an hour to figure out how this works coz I really like my 5320. gotta find a way to tweak and fix this anyhow =)
Well I have this particular cell and I've no trouble transferring any type of file or data. I don't use the data cable, instead I use the memory card thru a SD card Reader . That's the easiest way for me. I downloaded movies into this phone it really is a sweet phone. Hope that helps.
soft ware is not corrupt it is a miner problum. there is messege setting u will c there other setting there is sms center no. u miss that no. wich coumpani cell u used all companies have different no of sms center ok put the currect no
