Sony Bravia KDL-42V4100 42 in. LCD TV Logo
Anonymous Posted on Feb 17, 2010
No picture, red light flashing
No picture, red light flashes twice on the stand by display
  • Anonymous Feb 17, 2010
    did that. didn't work
Chi Chu
Level 3:
  • Sony Master 8,457 Answers
  • Posted on Feb 17, 2010
Chi Chu
Sony Master
Level 3:
Answers
8457
Questions
0
Helped
2823148
Points
26282
Power supply board is dead.Replaced the power supply board well solved this problems.
  • Chi Chu Feb 17, 2010
    The Main Tuner Signal board also dead.Replaced that board too.Rare but it happen some time,power short circuit the Main Tuner Signal board too.
E25
hello,
All error codes start with the letter "E". An error code of E11 will have the five indicator lights flash once and the Start indicator light flash once.
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
If the five indica
tor lights flash more than nine times, this signals a letter in the error code. The letter "A" stands for 10 flashes, "B" for 11, "C" for 12, "D" for 13, "E" for 14 and "F" for 15 flashes. An error code of EB2 will have the five indicator lights flash or blink 11 times, and the Start indicator light blink twice
hope this help?
thanks.
Oct 23, 2010 • Dishwashers
4helpful
I have a KDF-E50A12U Sony TV it won't turn on and keeps Flashing red twice, no other lights are on, just the stand by continually flashing twice.
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
1helpful
3answers
The red standby light is flashing twice with a pause, then twice and a pause etc. There's no picture or sound and the light flashed whether we have the tv on or off. Any suggestions?
This blinking is a diagnostic code. Please update this with the model number. These sets contain circuitry that will shut the set down and display a code like this when a problem is detected. With the model number, I can look up the problem and provide potential repair suggestions.
Thanks,
Dan
Tv stand by red light flashes twice continuosly
This unit is having a problem with component failure and is going into the protection mode. This protects the unit from further damage. You will have to take or send your television in for testing and service.The service center will have all the service information to analyze the problem and do the repairs. If you had given the brand name and model number of the television, i could have directed you to a customer support website or telephone number. This information can be found in your owners manual. I hope this information helps you with your problem.
Stand by light flashes red on powering up with remote and the green light flashes approx 15 or times before the screen illuminates.
thats pretty normal, it takes a good second or two to warm up and the display to turn on(at least0, you get the green flashes as you hold for on, 1 sec is a long time at times, lol, be patient, no problem with your tv!
3helpful
Cannot get tv out of stand by mode..
upon hitting the power button, the red light showing on the front of the tv should flash a couple of times, the screen should come on and the light goes off..the red "stand by " light stays on and we cannot get the screen to come up..needless to say, cannot get to the menu to change any display options...any suggestions?
3helpful
4answers
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
2answers
TV won't turn on, red light flashes twice
your tv has hardware problem and Sony service person can fix it.
152helpful
14answers
Sony tv repair
I own a Sony T.V. model #KV36HS510, Serial # 9024184,Event# E36002407 and it"s aTrinitron brand name. Like the problems before no picture or sound, stand by light on front of unit flashes. When trying to turn it back on you can hear the power click, like it wants to turn on, but does not.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
