You can try the following. Remove all paper from the printer and
turn printer off. Try opening the printer as if you were to remove the ink cartridges and
check for any paper jammed in the printer. If there is a paper jammed
try to remove it. if there is no paper jammed in the printer then try
the following remove all paper from the feeder and flip the printer
upside down and shake it a little. Sometimes things will fell inside of
the paper feeder and will block the paper path thus causing the printer
not to be able to pull the paper.
SOURCE: Dell Laser Printer model 1700
I'm having the same problem. The arm with the wheels will not drop down. any suggestions?
thanks
SOURCE: lexmark z2300 printer won't pull in paper
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
SOURCE: the printer is not pulling the paper into the printing mechanism
My printer is blinking and not pulling paper. That apart there is word showing mechanical error and cartridge craddle cannot move etc. etc. but sometimes it is found OK.
Manabendra
[email protected]
SOURCE: Printer will not pull in paper to be printed on.
Try these steps :
SOURCE: HP Officejet 6210 will print but with terrible clicking noise
Ok this Sounds Crazy but it worked for me and its easy to try. Unplug the unit and pick it up and turn it side ways and gently shake it. Sometimes a small piece of plastic has broken loose and is interfering with the works and if you can dislodge it from its current location it will stop. Be careful not to hurt youself doing it. Also, I have one printer with a missing tooth on one of the gears and has been growling at me for a long time.
Best of Luck,
RSMITH972278
