Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
Posted on Feb 16, 2010
My vacuum is picking up very little. No debris is
My vacuum is picking up very little. No debris is being deposited into the bagless cup. I have to stop every 2 minutes to unlog the hoses.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 19, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
296
Points
I have the exact same problem. The beater seems to turn just fine and the dirt is getting picked up, on it just sits in the hose. I don't think it's the best because it seems find, but who knows? Please help.
Why is my vacuum not pick up
Hi! Your vacuum is most likely not picking up because of a clog, dirty filter or worn belt or a combination of the three. Please try these trouble shooting steps below.
1. Check that the brushes are still spinning. If not replace the belt.
2. Remove the hose from both ends. Use a broom stick to loosen and remove any clogs from the hose.
3. Remove the dirt cup. Remove the red baffle tube by rotating 1/4 turn counter-clockwise. Clear the baffle tube of any hair or debris. Replace the baffle tube.
4. Remove the filter from vacuum base. Hold filter under running water to rinse. Allow 24 hours to air dry before replacing.
Hope this helps get your vacuum back up and running!
Reduce suction Dyson DC41 Animal Complete Upright Vacuum
Hello, this is Ava with Think Crucial.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty the it. If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
Uncleaned filters may also the reason why your vacuum has lost suction. To clean the foam and felt filters, remove the dust cup and pull out the two filters that are on the top of the motor base. Rinse the filters with lukewarm water until the water is running clear. Let the filters dry fully before putting them back into the vacuum. If your vacuum is still not picking up dirt, you may need to replace it.
Unfortunately, if none of the other solutions worked, your motor is going bad. Most of the time a new motor costs as much as the vacuum itself and it is not easy to replace the motor. It may be time for a new vacuum.
You can purchase a wide variety of high quality Dyson replacement parts for your Dyson Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=dyson
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Dyson dc 40 loses suction
Ava B.
My Shark vacuum is losing suction. How do I fix that?
You can purchase a wide variety of high quality Shark replacement parts for your Shark Vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=shark
Ava B.
No suction on dyson dc07
Ava B.
2helpful
Does not pick up
Hi There,
It may be that your belt is broken, or stretched out. This will cause the brushes to slow down dramatically when vacuuming the carpets. When the belt stretches, this causes the machine not to pick up on the carpets, and makes it seem that the vacuum is loosing suction.
In order to test this, turn the vacuum on it's side while it's on. Are the brushes spinning? If they aren't, this is because your belt is broken. If the brushes are spinning, the belt still may be stretched. Listen to the brushes as you put them onto the carpet. Can you hear a change in the sound like the brushes are slowing down? If you put just a little pressure on the top of the vacuum by stepping on it, do the brushes stop then?
It may also be the filter is clogged in the machine and needs to be replaced. Bagless vacuums use a HEPA filter in the dirt cup instead of a bag. With a bagged vacuum you just replace the bag when it gets full, but on a bagless vacuum the HEPA filter continually gets debris and fine dust accumulating on it, and needs to be cleaned, and replaced occasionally.
Here's a link to the owners manual for your vacuum. This will explain step by step on how to replace the belt, as well as servicing the filter.
http://www.dirtdevil.com/manuals/?id=83831cab-2807-439b-811d-52aab2fd84ee
If you still need some help, please just use the comment field here on Fixya to ask your question. I'm always more then happy to answer all follow up questions, and I really am not completely satisfied until you are able to fix your vacuum.
If you found this repair helpful, please be so kind and rate the repair, or leave feedback. This is greatly appreciated.
Thanks,
Chris Jones
GoVacuum.com
My vacuum (shark modle #UV210BV) turns on but has absolutely no suction.
If the dust cup is too full, there is no space for the dirt to go when you are vacuuming. To fix this, remove the dust cup and empty it. If your vacuum is still not picking up dirt after emptying the dust cup, there may be something blocking the airway. There are two places where you can check for a blockage: the dust cup air duct and the intake opening behind the brush roll. To check for a blockage in the dust cup air duct stand the vacuum upright and remove the dust cup. Now you can disconnect the super stretch hose and check for clogs in the air duct behind the dust cup. If that is not the case, to check for a clog near the roller brush lay the vacuum down. Next check the opening behind the brush roll for clogs. If there is debris, clean the opening with scissors, carefully cutting away any debris.
You can purchase a wide variety of high-quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
Ava B.
My self-propelled windtunnel bagless hoover does not pick up.
Remove the filter screwed in at the top of the dirt cup opening.
Remove the hepa filters on the side of the machine.
Clean all filters and re-install them.
Debris in front of foam filter
when that happened to me it was because the cup got full or was loose. I am now seeing the cup seal, located on the body above the cup, is not sealing and my filter is loaded. That might be a clue.
Self-propelled windtunnel bagless
Either the inlet down by the brush roll is clogged, or the hose is clogged. Check that out and if you still have a problem, then take it to a warranty repair shop, you have a 1 year warranty on this. Take your sales slip as proof of purchase.
Top Eureka Vacuums Experts
Mike Cairns
Mike Cairns
Jo Ri
Level 1 Expert
Alexander
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
