In that case you need a service call. The model number is on the sticker by the mains lead. Try cutting the power overnight to reset, but it sounds like a main control board issue and they are expensive. You are the only person with this problem!
It sounds as if the d/washer is pressurising due to a blocked outlet drain hose.
Make sure that the drain for the dishwasher is actually clear take hose out of the drain outlet.On some of the Beko dishwashers they put a plug up inside the drain hose which has to be removed before use or if it is a new installation and it is draining into a "U" bend on a sink check that the little spigot that the hose is onto is actually open.They come from the plumbers merchants blanked if blanked then you have to cut the end off to suit size of hose.I hope this has helped.
Your fault is not the normal complaint. Question is, "are you sure it doesn't just keep on running during the heating cycle"?. My thoughts are the heating element is possibly not functioning which will disrupt the continuing of the cycle.. Check element for a resistance reading,(approx. 23ohms). Check for a thermal cut out (sometimes a little reset button found on an item with wires attached). Press until click is heard.Retry. If all this heating does happen, then there is definitely an issue with the timer being it electronic or mechanical. Please let me know if not the solution. Thanks.
cannot reset dishwasher any help please
