When we start the TV the power/standby led goes green and than goes to red and flashes 6 times than goes blank followed by again 6 red flashes it keeps doing this sequence. There is no video or sound.
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Mar 17, 2012 - 14 posts - 4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Type in the brand name and type of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
It sounds that the main digital board has damaged. 12 blinks indicates it. if you wish to know more check this link for more details about 12 blinks to Emerson TVs
I suspect you probably have a bad LED assembly. It could be either the red, green or blue that is bad and give you the same symptom. The problem is locating parts for it as it looks like the light engine is no longer available. I would have a technician look at the TV to verify this and what parts are needed for repair.
The POWER/STANDBY (red) indicator flashes three times If your power/standby indicator is flashing in a pattern of three flashes, this may indicates that the lamp cover is not attached securely. Follow the directions in the Operating Manual under changing your lamp that related to closing and securing the Lamp Cover. Ensure that the Lamp Cover Door is securely fastened by tightening each screw.
The POWER/STANDBY (red) indicator flashes continously If your power/standby indicator is flashing continuously, and the lamp cover has been secured, your TV may be in need of service.
The POWER/STANDBY indicator is lit up green (not flashing) A sustained green light indicates your TV is on.
The POWER/STANDBY indicator is lit up red (not flashing) A sustained red light from your power/standby indicator simply indicates that your TV is in standby mode. This shows you that your TV is ready to be turned on with the remote.
Is it the power light and not the lamp light? If the lamp light is flashing then replace the lamp.
I have a sony tv PFM-42B1 when I turn it on it go to standby an a red light flash I count count 14 time but I heard that it only support to flash 1 to 6 time how do count the flash
