i just got a glofiish of ebay. I insert my sim card and turned it on and its asking for an password? :(.
Full message: "Serveral incorrect passwords have been entered. to continue password entry enter 'a1b2c3'. In case of emergency enter an emergency phone number"
The ebayer told me he hasnt set up any passwords on it so there for im not sure what the hell is going on.
Visit www.pdaviet.com and download a cooked ROM. I suggest version 3 (V3) Unzip the ROM to an SD card. The SD card must be formatted in FAT16 not FAT32.
Make sure you have a FULL CHARGED BATTERY! Unzip the cooked rom file you donwloaded from pdaviet and copy it to main (root) directory of your SD card. Insert the SD card into your glofiish, hold the Record, Camera and Power button at the same time and while holding them, press the reset button and then release the reset button, continue to hold other buttons untill you see the USB download screen. Let it do its job, it will be finished when it says.. not connected.
Removed back cover, remove battery for few seconds, replace both and then power up.
It looks like you're unit is locked to the carrier (similar to cell phones). You'd have to get an unlock code that will allow you to place any SIM card inside you're unit.
There are usually vendors that will do it for a nominal fee.
1. First do a CUSTOM reset: *2767*2878#
2. Take a wrong network SIM and insert a half of it, so when you turn on
the phone it don't detect the SIM. Very important so it won't ask for
network password and shows "Insert SIM" message.
3. Now take out the battery a little so you can insert fully the SIM
without turnig off the phone, at this stage the phone is still asking to
"Insert SIM" with the WRONG SIM inside.
4. Make a FULL reset: *2767*3855#
5. The phone should reboot working with "wrong" sim inside.
6. Change the NCK password to 8 zeros: *7465625*638*00000000*00000000#
7. Disable network lock: #7465625*638*00000000#
. First do a CUSTOM reset: *2767*2878# (star 2767 star 2878 hash) turn off the phone 2. take out the battery and sim and put wrong network SIM and insert a half of it, so it won't ask for network password and shows "Insert SIM" message. Now put the battery ,and switch the phone on .(phone shows "Insert SIM" message.) 3.With out turn off the phone push the sim fully in. At this stage the phone is still asking to "Insert SIM" 4. Make a FULL reset by typing: *2767*3855#(star 2767 star 3855 hash) 5. The phone should reboot working with "wrong" sim inside. 6. Make a Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000# (star 7465625 star 638 star 8zeros star 8zeros hash) 7. Now Disable network lock By typing: #7465625*638*00000000# (hash 7465625 star 638 star 8zeros hash) Phone is unlocked (check with *#7465625#)
PLEASE BACK UP YOUR FILES BEFORE UNLOCKING This will also bring the phone to default settings 1. First do a CUSTOM reset: *2767*2878# turn off the phone 2. take out the battery and sim and put wrong network SIM and insert only a half of it, Very important so it won't ask for network password and shows "Insert SIM" message.(possibly in a different language) Now put the battery ,and switch the phone on .(phone shows "Insert SIM" message.) 3.push the sim fully in at this stage the phone is still asking to "Insert SIM" 4. Make a FULL reset: *2767*3855# 5. The phone should reboot working with "wrong" sim inside. 6. Make a Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000# 7. Now Disable network lock By typing: #7465625*638*00000000# Phone is unlocked
try these, First do a CUSTOM reset: *2767*2878# Make a FULL reset by typing: *2767*3855# 1. First do a CUSTOM reset: *2767*2878# (star 2767 star 2878 hash) turn off the phone 2. take out the battery and sim and put wrong network SIM and insert a half of it, so it won't ask for network password and shows "Insert SIM" message. Now put the battery ,and switch the phone on .(phone shows "Insert SIM" message.) 3.With out turn off the phone push the sim fully in. At this stage the phone is still asking to "Insert SIM" 4. Make a FULL reset by typing: *2767*3855#(star 2767 star 3855 hash) 5. The phone should reboot working with "wrong" sim inside. 6. Make a Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000# (star 7465625 star 638 star 8zeros star 8zeros hash) 7. Now Disable network lock By typing: #7465625*638*00000000# (hash 7465625 star 638 star 8zeros hash) Phone is unlocked (check with *#7465625#)
It is not possible to know your unlock key. If you want to unlock the mobile here is the simple method Note: back-up your importent data before doing this.
--------------------------------------------------------------- If you find posts helpful, answer 'Yes' below
I believed someone had entered too much inccorect passwords so it totally locked. You probably try a Hard Reset to bring the unit back to default setting but you may loose some data in it. To perform hard reset just hold the power button and reset button with your stylus at the same time and push.
I bought this off ebay never worked for me,but try it you never know..............................
1. First do a CUSTOM reset: *2767*2878# (star 2767 star 2878 hash) turn off the phone 2. take out the battery and sim and put wrong network SIM and insert a half of it, so it won't ask for network password and shows "Insert SIM" message. Now put the battery ,and switch the phone on .(phone shows "Insert SIM" message.) 3.With out turning off the phone push the sim fully in. At this stage the phone is still asking to "Insert SIM" 4. Make a FULL reset by typing: *2767*3855#(star 2767 star 3855 hash) 5. The phone should reboot working with "wrong" sim inside. 6. Make a Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000# (star 7465625 star 638 star 8zeros star 8zeros hash) 7. Now Disable network lock By typing: #7465625*638*00000000# (hash 7465625 star 638 star 8zeros hash) Phone is unlocked (check with *#7465625#)
Please follow the instructions carefully! Following are the 12-point instructions to unlock your Samsung E250 phone:
1. First do a CUSTOM RESET by tying in:
*2767*2878#
(Phone may display foreign language – don't worry! The last digits after the * will appear as - - - -; this is normal)
2. Turn off your phone
3. Take the battery and SIM out of the phone
4. Take a wrong network SIM (a SIM the phone does not currently accept) and insert it ONLY HALF way in, so when you turn on the phone it won't detect the SIM. Very important so the phone won't ask for network password and will show "Insert SIM" message.
The process of inserting only half of the SIM. I advice you to take care and do it with a soft approach as you might not have done this before.
5. 2. Now put the battery in carfully behind the protruding SIM card and switch the phone on. The phone must show "Insert SIM" message.
6. 3. Without turning off the phone, now push the SIM card all the way in, at this stage the phone must continue to display the "Insert SIM" message with the WRONG SIM inside.
7. Now make a FULL RESET by typing: *2767*3855#
9. Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#
8. The phone should reboot working with "wrong" SIM inside. (Do not turn off the phone)
10. Disable network lock by typing: #7465625*638*00000000#
12. Check this is done with *#7465625#
If your phone is not unlocked please retry the above ensuring all steps are followed to the letter, 9 out of 10 people who have problems have made a simple error and find that when they repeat all the steps it works.
