dude firstly you need to connect it to your machine viya usb cable or ethernet cable then you need to install its dribvers in ur comkputer and then make it ur default printer then u ll can send the printouts to it
set up the copier derive again & set the paper size Make sure that the tray's paper size setting is the same as the tray's paper size setting in the printer driver. For example, if the tray's paper size setting is A4R (LT-R), set "Setting Paper Size" to "A4-R".
Toshiba e-Studio 166 is compatible with Windows 7 and drivers are available Toshiba Official Support Visit the above link Click 'Support & Drivers' Choose B/W Copiers Choose e-Studio 166 Select the complete driversand download the zip file.
Hope it helps! Good Luck! Don't forget to convey your feedback CreativeTECH
You are trying to print to paper size that is not installed in the machine. Check what paper is installed in the machine then set your software application default paper size to the same value and then print away!
