I need to connect my motorola bluetooth to an old razor phone, but the phone is asking for the bluetooth password and I do not have the manual for the bluetooth. Can I reset the bluetooth?
yeah the default pin 0000 its a standered security feature in all bluetooth devices.if 0000 dont work check your manual for it,, but I'ts more than likely 0000
Hi,it all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device. Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Yes,You can connect the Jabra head set to motorola razor.
Please follow the steps to connect it to motorola razor
1. Turn headset off. Press and hold until solid light comes on. 2. Activate Bluetooth on your phone. 3. Search for Bluetooth devices and select Jabra BT2070. 4. Press ‘OK’ on the phone ,If the phone asks for a PIN then confirm with PIN code 0000 .
when you place the bluetooth in pairing mode and search for it from your phone it should automatically connect
if it asks for a passcode then press 0000
if this does not work try it with another phone or try to connect another bluetooth to this phone to see if there is an issue with the bluetooth on your phone
