I don't know how much water to put in the bucket
A dehumidifier does not need water in the tank.It takes humidity out of the air and the moisture goes into the bucket. A humidifier has to have water in the tank.Note ,a humidifier puts moisture in the air, and a dehumidifier takes the moisture takes moisture out of the air.
Is this question a joke???
SOURCE: Dehumidifier Error?
Your bucket full switch may be defective. If you are capable, bypass it since you are draining to another place other than the bucket.
Same problem with Goldstar model DH404EY7 -- stop code 01 on startup, bucket full light blinks (drains to floor).
Replaced the main controller board to fix it.
For my model dehumidifer the part # is 6871A20888A, and cost $77.44 (not counting shipping) from Appliance Factory Parts. The Appliance Factory Parts web site also provides parts breakdown (exploded parts diagram) diagrams and service manuals in PDF form.
SOURCE: Are you supposed to put water in the bucket of the
The dehumidifier condenses the water on its coils and then it drips into the bucket. Dump out all of the water when the bucket is full. This model has a light that tells you when it is full. If the dehumidifier gets ice on the coils, it needs repair (low refrigerant).
I hope this helps.
SOURCE: My Kenmore 580.54501 dehumidifier "Water Bucket
Here is a tip that explains what can be happening to make the dehumidifier showthat the bucket is full when it is not.
Dehumidifier Problem It shows Bucket Full
heatman101
SOURCE: 50 pt. dehumidifier will not
Nothing worked, because the drain hole to the hose connection is clogged or the hose is clogged. When that happens, water is diverted to the bucket.
Turn the Master ON/OFF Switch to OFF & Unplug the unit.
Remove the hose and check it for clogs. If none are found, the clog is inside the hose connector.
Using an 18" long plastic Zip Tie appropriately sized to fit the hole. Carefully insert the tip of the Zip Tie and continue to push it in, until you reach a bend in the tubing. You will have to gingerly work the Zip Tie past the bend, until it bottoms out or you run out of usable Zip Tie. Then slowly remove the Zip Tie while rotating (twisting) it. This will break up any clogs. As you reach the inserted end of the Zip Tie, be prepared as some water that might follow. Even if you don't see any residue from a clog, it may have been pushed out of the way. Reinstall everything, plug the unit in, turn the Master ON/OFF Switch to ON and take it for a test drive.
Be sure the hose is no longer than 5 feet and that it gradually slopes down and away from the unit. The water drainage relies entirely on gravity.
Hope this helped you troubleshoot and solve the problem.
