HP Pavilion dv6700 has system failure when connecting to TV
I have a HP Pavilion dv6700 which I used to be able to connect to my Sny TV with a HDMI cable. When Iconnect now the laptop has a system failue a blue screen appears and it goes through a recovery process that will only be fixed if I unplug the TV. Any thoughts?
Re: HP Pavilion dv6700 has system failure when connecting...
Try updating ALL Video Card & HDMI Drivers from manufacturers web site, that will probably be the best chance at a fix, this is a driver issue. Connect up this way... Start TV... plug in Cable to TV & PC, now, startup PC.
Testimonial: "Your solution solved my problem. It is much appreciated."
About it being an HP Pavilion dv6700 laptop? Ehhh, giveittome. I will use it.
Looks like I'm going to have to guess since the 'Issue' wasn't stated.
The main problem with the Pavilion dv6700, which is part of the Pavilion dv6000 series of Notebook PC's, is that all the indicator lights come up, but there are no graphics being shown on the LCD screen. The screen is black.
This is due to a graphics chipset problem, caused by a poor cooling design of HP designers.
The graphics chipset (GPU. Graphics Processing Unit), is mounted to the motherboard in a BGA surface mount.
Instead of pins coming off of the bottom of the chipset, as on the older Processors, there are Solder Balls.
The motherboard has tiny copper pads that line up to the solder balls. The graphics chipset is set into place, then heat is used to melt the solder balls, and attach the graphics chipset to the motherboard.
Due to the poor cooling design, the graphics chipset overheats, and the solder connections are partially melted. The graphics chip now has a poor contact to the motherboard.
This video shows you what's going on, and how to solve the problem,
hi mr. pavilion dv6700z. i have the same problem before but after i tried and use my genius mind. i made it. and the television is working in my laptop as a external monitor. pixel is good. just connect in card video out to video iput to television. [email protected].
Thank you. This has solved my problem
