SOURCE: Cannot scan from HP 6500 E709n (No Scan Options)
the shortcut is:
c:\program files\hp\digital imaging\bin\hpiscnapp
Testimonial: "Thanks, that totally worked. I still wish i could scan from the printer, though."
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue
The Out of Paper
message appears on the computer and the product stops picking up or feeding paper.
Solution
Step one: Reset the product
Step two: Check the condition of the paper and reload it
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
NOTE:
Do not load too much paper in the product.
Step four: Clean the rollers
Step five: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
CauseAny of the following issues can cause the error message to appear:
SOURCE: paper jam on a officejet 6500 wireless
Unplug the power cord and open the cover and remove all the cartridge and try to look I inside around the roller and try to manually roll the roller and if you can see the paper try to pull is slowly.
Have a nice day and do not forget to rate please...!
SOURCE: Connecting the HP OfficeJet 6500 to wired & wireless computers
Use the disk that came with the printer and install the software in both the computers based on the os installed in the individual computers, ping the ip address of the printer from both the computers, and then test for the functionality
SOURCE: hp officejet 6500 printer keeps
Kim, I have an HP 4200 that had a similar problem. It turned out to be the after market ink cartridge I was using. I secured a real Hp cartridge installed it and it cleared the problem. Hope this helps.
Ed
If you need more help come back.Post /
thumbs / testimonial are
welcome!
