Windows did not start, there is 5 options safe mode etc a blue screen flashes and this repeats, blue screen says , disable bios memory options such as caching or shadowing but options don't appear to be available??????
Try taken the bios battery out for about 30 secs, replace it and then reboot, after post press F8 untill you have a screen pop up with a safe mode option use the arrows keys to navigate to safe mode and press enter. In safe mode goto my conputer c:drive(boot drive) windows. In the windows folder look for a file called prefetch, delete all it contents. Exit out of everything and restart the pc. If same thing happens post back.
The Blue Screen of Death. Yes, I have had it many times. You can try to restart the computer using the F8 to enter safe mode. Then shutdown and restart. This usually happens when a file has been corrupted, normally by a virus or improper shutdown. If this doesn't repair the problem your left with trying to re-install the OS to fix the bad file. If yo can't get to safe mode your only option is trying to re-install the OS. If you see an option to install or repair choose repair to get the machine back up. I saw this a lot with ME, if you have Windows ME, get Windows XP and upgrade since Windows ME has so many bugs that XP would be a much better option.
This error comes when there is memory issue . Harddisk issue or RAM issue. For that if you have windows recovery disk you need to run disk checking program Most of this error comes becuase of hardddisk error. Boot your computer with windows xp disk then enter in recovery console mode then type in prompt "chkdsk /r" then press "y" then it checks disk andf fix error if found any error on harddisk. then you can boot your windows. Thanks for using fixya. Please rate my solution if it hleps. Pls let me know if you need more assistanse. Many Thanks .
If you have the boot disks that came with the computer this is the media it is talking about.. After you re-load everything to your computer I suggest downloading AVG antivirus
Since it is a Toshiba Tecra if you are not worried about losing data on the laptop you can try turning on the laptop and start pressing the zero key. It should give you the option to restore your laptop if you haven't deleted the restore partition on the laptop.
try booting into safe mode (hit F8 repeatedly when you reboot until a safe mode option comes up) then if you are able to log in, go to the windows run prompt, type "msconfig" go to startup, disable all, services, disable all. reboot. see if it still does the same, if it doesn't one of those services are causing blue screen. Also try reverting to previous drivers if you did any driver updates, remove any new cards/hardware you might of installed recently.
If you can't get into safe mode, at a copy of any xp disk. boot up from it. (make sure your boot devices are set that cd rom is before hdd in cmos setup) then go to the recovery console "you press 'r' when ou have various option" type 1 for the windows, enter. enter for password unless you previously set an admin password.
Then type "chkdsk /p", let it run also type fixboot, and say yes. reboot and see if this solves your problem.
