Epson Stylus DX4450 All-In-One InkJet Printer Logo
Posted on Feb 15, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
PLSE HELP IM TRYING TO PRINT BUT NOTHINGS HAPPENING, IT IS ALL SET UP
Anonymous
Level 2:
Scholar:
  • Expert 83 Answers
  • Posted on Feb 16, 2010
Anonymous
Expert
Level 2:
Scholar:
Answers
83
Questions
0
Helped
40111
Points
173
Test the printer first, so that we can isolate the issue. print a nozzle check to eliminate the possibility that the nozzles are clogged by dried inks. if nozzle check prints blank page or it printedr but w/ gaps or breaks, do head cleaning
Check the Print Head Nozzles: 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus CX4400 Series. 3. Hold down the PLSE HELP IM TRYING TO PRINT BUT NOTHINGS - cx4400_ug.1.79.1.jpg Stop button as you press the cx4400_ug.1.79.2.jpg On button to turn the Epson Stylus CX4400 Series back onPLSE HELP IM TRYING TO PRINT BUT NOTHINGS - cx4400_ug.1.79.3.jpgtons until the cx4400_ug.1.79.3.jpg light begins to flash, then release the buttons. cx4400_ug.1.79.4.jpg PLSE HELP IM TRYING TO PRINT BUT NOTHINGS - cx4400_ug.1.79.5.jpgCheck the nozzle check pattern that prints to see if there are gaps in the lines. cx4400_ug.1.79.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. PLSE HELP IM TRYING TO PRINT BUT NOTHINGS - cx4400_ug.1.80.1.jpgead Nozzles: 1. Load a few sheets of plain paper in the sheet feeder. 2. Hold dowPLSE HELP IM TRYING TO PRINT BUT NOTHINGS - cx4400_ug.1.80.2.jpgoads/images/cx4400_ug.1.80.1.jpg" alt="PLSE HELP IM TRYING TO PRINT BUT NOTHINGS - cx4400_ug.1.80.3.jpg" class="h_mi" /> Stop button for at least 4 seconds to start the cleaning cycle, which lasts around 1 minute. cx4400_ug.1.80.2.jpg The cx4400_ug.1.80.3.jpg On light flashes throughout the cleaning cycle and stays on green when the cycle is finished. Caution:
Never turn off the Epson Stylus CX4400 Series during a cleaning cycle or you may damage it. 3. Run a nozzle check to confirm that the print head is clean. You may need to clean the print head up to 2 times. You can also turn the Epson Stylus CX4400 Series off and wait at least 6 hours. Then try printing again.
Laserjet p2055d.when print 1doc it prints extra blank page. what could it be?
I had the same problem. Try adjusting the setting to fit on one page (did not work for me on my hp but worked on my brother MFC) or remove the device and reinstall with updated drivers
Can u plse tell me how to reboot!!! im a beginner, i barely understand the computer, i know how to type but nothing else & at times i get lost doing that!HELP PLEASE!!!!!!!!!
Hold the power key at the top right hand side and the circle home key button at the same time for a 10 seconds to try to reset phone , or go into settings /general to try to see if you can find default factory settings
Lights flashing says print head is incorrect,install correct print head,but it was the same print head,it just appear..canon pixus mp 600,what can I do plse
Hi. Unplug the printer from its power and try this.1. Pull the cartridges out 2. Remove the print head, and re-install making sure the metal contacts on the side line up with the ones in the printer. it can appear to be in OK but use a strong light to make sure it is lined up correctly. 3. Re-Install the cartridges and try again.
This can also happen with some compatible cartridges or ones that have been re-filled and re-set too many times. The black cartridge is usually the issue in this case.
I hope this helps Regards GM
1helpful
2answers
My lexmark x4650 printer is connected to the wifi, but the orange light is blinking. And nothing is able to print. When I look at the printers activity it shows the document that im trying to print but...
When you installed your printer, you had to install the software on your PC. So go to your PC's start menu, go to Programs, select Lexmark software, select Tools and then select Wifi Configuration Utility. It will open a window which will give you step by step instruction on re-configuring your wifi settings. When you are doing this, make sure your printer is connected to your PC via the USB cable.
How to i print the menu settings for Tally T2240 plse ?
Press the SETUP key to enter the menu settings.
Press the key under "MENU", then press the key under "PRINT" and your current configuration will be printed.
If the menu shows as locked when you try to enter it, power the printer on holding down 'SETUP' this will unlock the menu.
Just changed cartridges - power is on - lights on - push COPY button, NOTHING happens
hi im josh in cebu phils. Friend may i helped you? if you've installed the cartridge then nothing happens. Your printer haven't  yet charge the ink. you go to printer settings the click the ink replacement just next next then after it will detect.you wait for a while the ink is charging it will take some time to complete. you wait it until it will told you to so.don't exit. then after go to ink status icon.check if it is confirm through the level shown.then thats the time to exit. then try to print. good luck
4answers
Operators Error - won't respond to anything
i have the same problem and im clueless as how to fix it :(
Print function isnt working
What a tank! Great machine. I have never tried to connect to a computer. What op system are you using? Windows Vista and maybe XP may not support this model. Look for undates. What cable are you using? I just checked with Canon and found this unit is supported by Win 95/98. A firmware update from Canon may solve it.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
