This is a known problem - there is no fix - if you call coby customer service they will tell you to try a dvd lens cleaner -this will not fix the problem. Best advise - throw it away.
Temperature of exhaust air too
High
Let it cool down?
Cause:
The oven cavity gets too hot due to excessive
operation with no load or small load, or due to
some blocking materials around the Air Filter or
Air Exhaust at the back of the oven.
Remedy: • Open the oven door and check if 1) the oven
has been operating with no load or too small
load, 2) the air filter is placed in a wrong
position, or 3) any blocking materials exist
around the Air Exhaust. Cool down the oven (for
approx. 30 min) under the normal temperature.
The oven is back to normal when the error
code "E3" disappears and "ON" appears again
in the display window.
• Unplug the power cord, remove the blocking
materials around the ventilation openings, cool
down the oven (for approx. 30 min) sufficiently,
plug the power cord in again and check if the
error code appears again.
• If the symptom persists even when the oven is
cooled down sufficiently, contact the nearest
service centre
Optical lens needs to be cleaned with good quality cotton swab gently that will solve your dvd problem. Unplug dvd player, take off top cover by removing its screws and clean optical lens. Thanks.
after choosing the disc # put the disc in about 1" and it should take it out of your hand and into the machine DO not try to push it in...
if you do it will stop/reject the disc...
There is a sensor in the tube that is a safety feture. it is a snap disc it maybe faulty, it is reading that the tube is to hot and shutting down, it cools and works again, check snap disc and also they need pleanty of fresh air.
there are a few possibilties
1 make sure the disc is clean
2 your lens may need cleaning
3 some dvd players don't read burn copies of disc's some just read +R discs some just read -R disc
DVD players are ****!! This is my 5th time buying one. It's like the industry is running a big scam because that know that soon all movies will be digital mp3. All of my players give me the same error!!
Solution: Wii Console needed to download a software upgrade from the web to run Guitar Hero World Tour. Internet connection in our home is via a Linksys ADSL wireless router. Entered Wii Setup menu (select Wii button on bottom left of screen). Changed Connection 1 from None to Wireless. Wii picked up the SSID broadcast from the router. Did a Test Connection which worked. Wii Console prompted me to 'download Wii System Upgrade from Web?'. Clicked OK. Download took approx 10 mins. On completion of download Guitar Hero World Tour loaded automatically. Note: I have read that the Wii uses wireless protocol 802.11b. Make sure your router has both 802.11g and 802.11b enabled or 802.11b only for the duration of the download. Best of luck.
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
If this happened after a power surge, it's possible that one or more capacitors in the power supply have been damaged, and that could cause the player to act up. Otherwise, the symptom you're experiencing is a classic one of the laser pickup not reading the tracks on the disc (assuming you meant to say it switches the disc after approx 5 Seconds). If it is within the warranty period, it would be worth getting looked into. You can get a good CD/DVD player to act up like this by placing the discs upside down on the platter.
Occasionally when I put in A dvd it will say wrong disc then after not using it for a whle I will put in a dvd and it will work?? What the heck??
Same problem. Every disc I put in reads "Wrong disc"
Is this a piece of junk or what?
