Besides the auto-flash mode, you can select fill flash, flash off, self-timer, and nighttime-view with or without flash.
Press the MODE-SELECTOR BUTTON until the desired indicator appears on the LCD PANEL.
Fill flash and flash off modes remain selected after you take the picture. To cancel the selection, press the mode-selection button or close and reopen the lens cover/flash to return to the auto-flash mode.
Fill flash
When bright light indoors or outdoors comes from behind the subject (backlighting), dark shadows (especially on faces) may occur. Use fill flash to lighten these shadows.
- Open the LENS COVER/FLASH to raise the flash and to turn the camera ON.
- Press the MODE-SELECTOR BUTTON repeatedly until the FILL-FLASH INDICATOR appears on the LCD PANEL.
- Frame your subject within the VIEWFINDER EYEPIECE.
- Partially depress the SHUTTER BUTTON. When the FLASH/CAMERA-READY LAMP turns off and the fill-flash indicator on the LCD panel stops blinking, fully depress the shutter button to take the picture.
Flash off
When you do not want to use the flash, especially indoors where flash is prohibited, such as in theaters and museums, or when you want to take twilight scenes or distant subjects that are beyond the flash range, or capture the ambiance of existing light, use the flash-off feature. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed in these situations will most likely be slow.
- Press the MODE-SELECTOR BUTTON repeatedly until the FLASH-OFF INDICATOR appears on the LCD PANEL.
- Press the SHUTTER BUTTON to take the picture.
Self-timer with auto flash
Use this feature to include yourself in pictures.
- Use the TRIPOD SOCKET to attach the camera to a tripod or place it on another firm support.
- Press the MODE-SELECTOR BUTTON repeatedly until the SELF-TIMER INDICATOR appears on the LCD PANEL.
- Press the SHUTTER BUTTON. The SELF-TIMER LAMP will glow and then blink during the last three seconds of countdown.
- To cancel the self-timer selection before the shutter releases, close the flash.
- The self-timer automatically turns off after the shutter releases.
Night-view with flash
In this mode, the camera balances the flash and existing light exposure so you can take beautiful pictures of people at sunset or at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
- Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR with flash appears on the LCD PANEL.
- Frame your picture in the VIEWFINDER EYEPIECE.
- Press and hold the SHUTTER BUTTON for 12 seconds without lifting your finger.
Note: If you remove your finger from the shutter button before 12 seconds, the shutter will time out immediately.
- After 12 seconds, release the shutter button to take the picture.
Night-view without flas
In this mode, you can capture the natural existing light of city-night scenes or fireworks at night. Use a tripod or place the camera on another firm support, and use high-speed film because the shutter speed at night will most likely be slow.
- Press the MODE-SELECTOR BUTTON repeatedly until the NIGHTTIME-VIEW INDICATOR without flash appears on the LCD PANEL.
Yes, with both lenses I have, 60 & 120 mm. Please look at the images.Thanks.
Thank you very much for the advice, Eltroman.
I'll try your advice when I got a chance to shoot on parquet floor. This drag flash effect disappears when working on cement floors.
Shootilldrop
Does this happen with all lenses or just one?
