The ASUS A8M2N-LA is the motherboard used by HP for the new D4500e AMD AM2 PC.
Here are the details:
Motherboard manufacturer's name: ASUS A8M2N-LA
HP/Compaq name: Nodus-GL8E
CPU/Processor Socket: AM2 Supports AMD Athlon 64, Athlon 64 X2, and Sempron processors
Front-side bus (FSB) 2000 MegaTransfers/second
Chipset GeForce 6150 LE chipset
BIOS features Award brand system BIOS Keyboard combination to used to enter BIOS: F1
Form factor Micro-ATX: 9.6 in X 9.6 in
Memory Four 240-pin DDR2 DIMM sockets, Supports PC 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs, non-ECC memory only, unbuffered Maximum HP/Compaq approved memory is 4 GB*
PS - as you can see the rangeis 533 - 667 MHz. I would suggest you call HP support and ask if it will support 800 MHz,
Sorry Here is the right specs
http://h10025.www1.hp.com/ewfrf/wc/docum...
I do not see why it would not the boards are very much the same except the 2 extra DIMMs on the HP so it is quite possible it will work.
Just checked the HP website and found out there board supports up to the Athlon 64 X2 5000+ heres the board practically the same.
Do not try to update your bios with the HP update check this link out.http://forums11.itrc.hp.com/service/foru...
That was a valiant try, Noligy, but the versions in the HP and Compaq are actually different even though their mobos share the same model number. For instance, I bet the HP version you reference has 4 dimm slots. The Compaq version has only 2. Check out the mobo drawings for each model and you'll see what I mean.
That's what I found, too. But there was some chatter on the forums that there was a bios update for a mobo by that model number. It seems that the bios update is for the HP version.
Question: Would the HP bios update work on the Compaq version, and if so, would it extend the board's CPU upgrade path beyond the 3800 listed on the link you referenced?
