SOURCE: model 11060052991 kenmore elite dryer
For heat issue I had replaced the heat relay switch a year ago and that worked. For the start button holding issue I replaced the motor relay switch and the dryer is fine again.
SOURCE: kenmore dryer model number 110.66912691 not heating.
Check the house electrical panel for tripped dryer-circuit breaker-pair. Push off, then on. If immediately re-trips, the dryer has a dead short circuit in it. If they hold, then retry the dryer. If it now works, ok! If not, recheck the breakers as above. If tripped again, there is a likely short in the dryer's heater assembly. The drum must be removed to access the heater.
SOURCE: I have a Kenmore Elite dryer Model:110.C60952990 almost no heat.
Before assuming you may have a component failure, do a little routine inspection of the dryer and exhaust vent ducting.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be because the exhaust ventilation ducting is clogged. If you can't remember the last time the exhaust vent was cleaned, or if it has never been done, this can contribute to dryer performance problems. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat, causing poor drying results and eventual failure. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced.
There is no lint screen that catches ALL the dryer lint. Some lint will always get exhausted with the moisture from your clothing. If the exhaust vent is kinked or has excessive bends that create choke points, lint will accumulate in these points. Once the lint starts to accumulate, the moisture from your clothes starts to collect in it, and more lint get trapped. This eventually creates a clog. The Rule of Thumb: The SHORTER and STRAIGHTER the exhaust ventilation ducting, the BETTER.
A simple test to determine if you have a clog somewhere is to remove the dryer hose from the back of the dryer and attempt to dry a load of clothes as you normally would. The air escaping the back of the dryer should be forceful and warm (about 140 degrees). If the air flow is normal and the clothes dry as they should, then you need to inspect the ducting thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs.
If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect.
If your exhaust vent runs to an attic, this is a poor design that gravity will always win because of the resistance the blower fan meets trying to push the exhaust up the wall. The lint will eventually collect in the ducting going up the wall and have to cleaned out from time to time.
Also, make sure you don't crush the dryer hose behind the dryer when you push it up against the wall. You should always leave plenty of space behind a dryer to prevent this from happening.
Rodents and birds are anotehr cause of dryer problems. If they have access to the outside exhaust vents, birds will build nests in them and mice love a warm place with plenty of bedding material (lint makes a nice nest). Make sure the exhaust vent is at least a foot from the ground and use a louver type cover to keep pests outside. Do not use a screen. It can resist air flow and clog.
In addition, you should be using semi-rigid metal type ducting that resists kinking, crushing and rodent infestation.
If the air flow is weak, then you need to inspect the dryer INTERIOR to see if the air blower is working properly and is not clogged. It is important to keep a dryer checked routinely. Failue to do so can lead to component failures and is a potential fire hazard.
If you have questions, please let me know. I hope this helps you.
SOURCE: I have a kenmore 70 series gas dryer. It won't
Check the thermal fuse and thermostats first, then the ignitor and the valve coils are the next possibilities.
Eric
