TV comes on stays on for approx 30 sec to 2 minutes. Then picture goes off, no audio and status indicator flashes 3 short times and then one long red flash and then the sequence repeats. I can clear the status by unplugging the TV power. TV turns on again but then I get the same thing, TV turns off flashing red status light 3 times and one long red.
Once the status light blinks 3 times, this is an indication that there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
SOURCE: I have a Mitsubishi WD-52327.
Replace the Lamp P/N 915PO20010 if it has never been replaced.
Mats Electronics has them for $99.00 1-800-628-1118
B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Have replaced the lamp. I have 2 of these WD-52327 TV's and I swapped the lamps. Lamp is fine. I also read it could be a possible lamp fan issue. Is there a way to get codes from the WD-52327?
