How to adjust my tilt of my 10'' artisan's powermatic table saw
Turn the crank...
When you are facing the saw as if you would be operating, there are two adjustment wheel on the front and right hand sides of the saw cabinet. The front wheel adjusts the blade height, the wheel on the right side of the cabinet adjusts tilt. Each of these wheels are equipped with a locking nut, a smaller wheel in the center. this must be loosened before any adjustments can be made and should be tightened before operation. If there is significant resistance while trying to adjust either of these it may be a result of misaligned gear or excessive buildup of dust and shavings on the gearing.
