Is it the SIM Card that came with that Tracfone? Becuase Tracfone's only work with the Sim Card they came with, not any other SIM Card. If it is, I'm not really sure how to fix it, except that you should try removing the SIM Card (located under or around the battery) and putting it back in again. Otherwise, you can contact Tracfone at their website, www.tracfone.com. Hope this helps! :)
How can i fix my tracefone
SOURCE: what is a tracfone sim
Follow these simple steps
1 - Input the code *#06# into your phone's keypad. Press the
"SEND" button. Listen for the IMEI number, which you will need to
provide to receive an unlock code.
2 - Contact your Tracfone cell phone provider. Ask the representative for an
unlock code. Give the representative your phone's IMEI number, model
number and manufacturer's name.
3 - Turn over your Tracfone. Remove the protective cover. Take out the
battery and place the SIM card underneath. Replace the battery and
protective cover.
4 - Input the unlock code as provided by your cell phone
provider. Press the "OK" button. Your Tracfone should allow you to
access the network.
SOURCE: tracfone says SIM blocked
myt phonw is acting up and when i turn it on it says sos calls only
SOURCE: my tracfone says the sim
Your sim card may be permanent lock and will need a new sim card.
Do not enter any more codes.
Contact Tracfone at 1-800-867-7183 or go on their website
to sent them an email. At the bottom of the website, click on Contact US.
Tracfone will be able to provide you with the PUK code.
SOURCE: How do i fix my
PUK stands for Personal Unblocking Key. This is a uniqueeight-digit code specific to your SIM card. This is required when the PINnumber to unlock your mobile phone is entered incorrectly 3 times. You are thengiven 10 attempts to enter your PUK code. If an incorrect PUK code is enteredafter the 10th attempt, you will block your SIM card permanently and willrequire a new SIM card from your mobile phone provider.
PUK codes can be obtained through the following ways -
The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.
