Call electrolux there was a battery recall
Here is a link regarding the recall. It only applied to some of the models and serial numbers so check yours before you assume that is the problem. Mine was having the same problem and it was solved when I replaced the charger plug with a new one. Be CERTAIN it is a 15v charger. Good luck.
No, not worn out batteries.
For my experience, if the batteries were
worn, they would charge with the blue led being on and after that, the
vacuum wouldn't hold his charge. just that.
This is a different
problem. Check the contacts between the charging station and the vacuum,
mines got bent a bit and stopped making contact. This has happened
twice and just fixed it about 30 min ago. That is why the led first
lights and then goes off, there was just a brief contact between them.
Nice vacuum, very powerful and handy but maybe it is just poorly made as it is engineered in Sweden but built in China.
