Kenmore 24632 Top Load Washer Logo
Posted on Feb 14, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Timer only works on heavy cycle not on normal model #11024632300
Kenmore top load washing machine timer only works on heavy cycle not on normal or delicate
Anonymous
Level 3:
  • Kenmore Master 3,361 Answers
  • Posted on Feb 14, 2010
Anonymous
Kenmore Master
Level 3:
Answers
3361
Questions
Helped
1030042
Points
10654
Could be a bad timer or loose contacts.
Unplug the washer.
Open the control console.
Remove the wire harness connector from the timer and re-insert it.
Also advance your timer manually 360 degrees around several times. This can cause stuck contacts to work correctly.
If this does not correct your problem you will need a new timer.
2answers
Washing machine will not start the wash cycle after filling with water. I have tried normal, delicate, and heavy duty cycles.
Not sure what model you are referring to, but in general, it sounds like a problem with the timer switch or if it's all electronic, then it will be in the control board.
If I had the model number I could be of more assistance.
Model #11024632300 doesn't spin or agitate.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11024632300/0582/0153200?pathTaken=&prst=0&shdMod=11024632300
and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Where is the water level switch or censor on washer model number 11024632300
See the following documents / sites:
First is the Sears Parts Site for your washer with diagrams and parts / prices:
Second is the Whirlpool / Kenmore Service Manual for top load, direct drive washers with diagnostics, testing and troubleshooting sections:
Third is an illustrated description of how to release the console and remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=0da65cea0e338fe930b1fde153a243f0
The water level switch is in the console.
Replaced lid switch a year ago, and the heavy duty cycle works fine. However, the permanent press/delicate and normal cycles do not work (tub just keeps filling/emptying water). My research indicates that...
I agree, it is most likely a timer problem. Possibly "rust" build-up.
See the Whirlpool / Kenmore Service manual for top load, direct drive washer for troubleshooting and diagnostics procedures.
1helpful
Doesn't spin
  • yes it does sound like the timer is bad.
  • the timer has small contacts in it (sort of like a music box) that lift and rest in certain places.
  • these contacts may not mate properly as the timer goes around slowly in the normal operation.
  •  but when you manually turn it is a faster turn and the contacts will fall faster and get a better connection.
Kenmore elite washer machine
The selections are all made by the timer control. I would look to this. Before replacing it, make sure the harness is connected nice and tight in the back.
Kenmore washing machine
you need to replace the timer it is faulty let me know how you make out
Kenmore/works on one cycle only
that machine have somes burn contacts on the timer replace with a new one and that is...good luck
Alexander
vince
