The printer says "error" and I need to replace my black cartridge. I can't get my kodak printer cartridge to move to the center of the printer so I can remove it. It says to open the lid and it will automatically slide to the center, but nothing happens. I've unplugged it, went through the help buttons, nothing will make it move.
SOURCE: cartridge slides too far left
Keep your printer on, lift the lid should be right in the center.
SOURCE: hp 812c cartridge cradle is stuck on the right, not moving to the
unplug the printer and try to move carriage by hand, if it does not move, the carriage mechanism is broken, if it does move, plug the unit back in, if same error occurrs, it is an issue with the printer carriage mech.
SOURCE: need to replace ink cartridges and the printhead
I have a kodak esp 5200 and just replaced the color cartridge. All you have to do is go to your little panel and go to maintenance. Scroll down to change ink cartridges and it will tell you to open the cover and replace the cartridge. I didn't know how either and just tried a few things. Hope this helps.
SOURCE: When replacing an ink cartridge in the Canon PIMA
I think your Motor as been stuck with some dust try to clean your Device then you can solve your Problem
