Carburetors are tricky, They have to be completely dismantled, soaked in carb cleaner, make sure all the gunk is off, every jet clean and clear, If you can't get a wire through it, you won't get gas through it, make sure you can blow through it, Get some guitar strings, .009 is about the smallest guitar string you will find, you can buy them separately at the music store if you don't have one. Change the filter in the line, when the carbs go back on, the adj all have to be the same, not one wide open and 2 idleing, Float level is also important, they don't sell complete kits anymore, you have to buy the parts individually, gaskets , etc, good luck.
Its good if you can follow these tips mate,because if as an person i would say i will go in short method.Try top go through this link maybe it will help you out mate.Cheers there..
How to Clean Boat Carburetor eHow
I have a 1986 25 hp mercury. Gas is leaking out of a small hole below the choke diaphram. Is that hole suppose to be pluged or is the leak telling me that my diaphram is bad
