Try charging it. once you hook up the charger and plug it on the wall switch, it should turn on if it doesn't wait some seconds and turn it on. if that doesn't help remove the battery from the phone and put it back in, it should turn on and reset.
first try replacing the batteries with a fresh one, having a battery logo with a lightning strike states that the batteries, including the backup battery has completely dried out, try charging it for a few hours. if there is no change and you still get the logo, maybe it would be safe that you should have it check at blackberry repair center.maybe some shortage or busted parts are causing such an error on your blackberry.
It sounds like your LCD screen got damaged. It may have been water damage or if dropped the connector for the lcd screen may have come loose
If you g=follow this guide, you can take the LCD apart and check to see if the able is seated probably. If it is seated, then theblackberry LCD screen is damaged and needs to be replaced.
Try this -- download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5 Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device. Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
