I have used your "Retro-Ring 4X4 [#206RAC] to anchor a two device-double receptacle box on a remodel and it worked fine. How do you use it for a single gang box with one receptacle? Is there a special 4X4 cover plate with the receptacle in the middle? How do you use the 4X4 Retro-Ring with a single 3X2 box?
The retro-ring 4x4 (#206 Raco) is intended for 4 square boxes. For a 3x2 box you should use Raco 977 box supports: http://www.grainger.com/Grainger/items/3XK12?Pid=search
If you have already committed, you can use a Raco 8787 (flat 4x4 cover):
http://www.hubbellcatalog.com/raco/RACO_datasheet.asp?PN=8787&FAM=RacoBoxes
