HP 32sII Calculator Logo
Posted on Feb 13, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The screen is very, very light. I replaced the
The screen is very, very light. I replaced the batteries with no luck. What now?
k24674
Level 3:
  • HP Master 8,093 Answers
  • Posted on Feb 15, 2010
k24674
HP Master
Level 3:
Answers
8093
Questions
0
Helped
4675240
Points
21596
To increase screen contrast
  1. Press and HOLD the [ON] key
  2. Press [+] key
To decrease screen contrast
  2. Press [-] key
My Google Android, the original, has nothing showing up on screen and no sound. There is power as the keyboard lights up. I tried swapping out the battery without any luck.
Sounds like the optical cable is frayed in the phone. I would probably just replace the phone as fixing the cable means replacing the gyroscopes and honeycomb touch screen. It will cost as much to fix as it would be to buy a new one.
Compaq presario cq61 screen went dark but can still see window faintly through the dark sreen.
Look at the LCD screen very closely and check if you can see a faint image on the screen. It's possible that the LCD lid close switch stuck in the "closed" position and the back-light stays off even when you open the LCD screen or turn on the laptop. The switch turns off the back-light when you close the LCD display to save the laptop battery power.
If no luck, try to remove battery and drain the power, then replace battery and turn on.
If that didn't fix it then there are 3 things that could have gone wrong:
1. Video cable connection from inverter to LCD got loose. To check this, follow instructions from step 3 on how to open the LCD and check if cable is fitted properly.
2. The video inverter is faulty
The screen inverter failure is very similar to the back-light lamp failure. In both cases the screen gets very dark and the image on the screen becomes very faint, barely visible under a bright light. If it's still under warranty, take it for a replacement. You can replace this otherwise - you can find the inverter under the screen, follow the procedure described at point 3 to open up the screen.
3. The LCD monitor is faulty
If it works on an external monitor most likely the LCD is faulty and needs replacement. If it's still under warranty, take it for a replacement. If not, you can do it yourself, it's pretty easy. Remove the rubber covers on the side of the screen, unscrew the screws take the plastic cover off, disconnect the video inverter and put in the new LCD after you connect the video inverter to it.
BB Bold 9000 is plugged in. battery is inside and the screen is black with flashing red LED light, then it switches to a white screen with a blue lightning bolt and goes back to the black screen with the...
Sounds like the battery is completely drained. Remove and replace battery, and charge for a couple of hours with your AC charger. If it still does not fully charge, you may have a bad battery. Good Luck...
Oct 18, 2010 • Cell Phones
With the laptop plugged into the power cord, pushing the power on button only illuminates three small green lights near the power button and the screen remains blank. Removing and replacing the battery...
Reseat the ram. Listen to see if the hard drive is engaging. If you hear the hard drive try replacing the cmos battery. consult manual for location of battery. I've replaced a couple in different models recently this fixed Them all. They use some cheap battery that didn't even test to 3.0 volts. Good luck
My sons ds lite will not turn on the green light comes on and a white light flickers on bottom screen and thats all, I changed the battery and still no luck. Help! thanks
it's likely that the top screen ribbon cable has either become damaged or loose, the entire top screen will probably need replacing (along with the casing if the hinge is broken).. if you are not confident with technical or fiddley things I wouldnt recommend attempting it yourself.
Phone won't turn on
Try removing your battery and replacing it in the phone.
if you don;t get any results, buy a new battery.
As long as you haven;t dropped the phone or got it wet. Replacing the battery should handle your problem.
you can also try a different charger before you go to the battery.
Good Luck
3answers
When my computer boots up, my screen is still black!
do check the LCD brightness settings..its usually on the function keys..you press the function key and the other key at the same time there should be a icon on the keys..some laptops have the arrow buttons(up,down or right and left) for controlling brightness...hope it helps!
Lighted keyboard
Had the same problem. Removing the battery and replacing it to perform a soft-reset fixed the problem for me. Good luck.
Toshiba A105 sat. laptop
No, no need for hard drive. Press and hold the FN key and press F4 once, if nothing happens try it again. If screen appears then your in luck. Otherwise the back light needs to be replaced for your LCD screen. Try an external screen and press FN+F4 key and you should have a screen so you can see if there are other problems. Good luck!
I was installing a program, and the screen went black adn the system shut down.
remove battery and try ac-power if laptop boots up then battery need replacing but if no laptop bootup then take it to be repaired and tell the tecnition what happened and he or she will try other options to get you going again. good luck on problem.
k24674
Grand Canyon Tech
Grand Canyon Tech
