N75/ fEE My nikon N75 is flash fEE on the l.c.d. display and in the view finder. It will not let me take any pictures, load film, it wont autofocus, the flash wont open, it wont do anything. How do I fix it?
The camera requires you to set your lens aperture at the minimum setting, usually orange coloured. I.E. f22 f32. Nikons control the aperture through the camera, not setting the ring manually like old style SLR's
Try resetting the camera by pushing both rewind buttons (two buttons with red rewind symbol), and when the motor stops running open and close the back door then try again. If not it could be as simple as a bad release switch (the switches on the N55 and N75 were garbage) or a electronic problem. Also check to make sure you did not pop the shutter blades out of position when loading film. Remove the lens and gently lift up the mirror with a fingernail and make sure the blades are flat.
If the LCD panel shows "E" then the film isn't loaded properly. If the LCD panel shows "ERR" and "E" blinking, then the film is not correctly advanced. If the LCD panel shows a blinking "E" when the exposure meter is turned on, then film remains in the camera after it has been rewound. In all cases, reload film.
If it's not one of those cases, or if the problem persists, please reply to this post giving further details.
Turn the aperture ring on the lens to its smallest setting (largest F/number). If the ring also has a lock, lock it in place. You control the aperture from the camera body, just as you would on a lens without an aperture ring.
depending on the type of film you are using and where you are taking it could be the problem. if you are using professional film and taking it to a pharmacy to get developed, the chemicals used at these places will erase the images off the film and appear as if the film is blank.
Sounds like a lens diaphragm problem ( lens stays closed down to F16 and that is why you have a dark viewfinder ). Remove lens and see if you can activate the aperture mechanism via the activator which protrudes from the rear of the lens. You should get nice and brisk action from the aperture . If the movement is sluggish or the lens stays fully closed then your lens needs attention.
When you get a flashing EE, it means there is an Eror somewhere.
Most cameras have a botton you press to reset it. Usually it is the battery check button.
Try that.
Also try taking the lens off the camera, unlocking the aperture ring, remount the lens and then lock the aprture ring to the minimum F stop.
I think this should solve the problem.
Quick solution: force a manual rewind.
1. Remove film
2. Close camera back.
3. With the power turned on, press the two rewind buttons together. They are marked in red.
4. The camera will make a rewind sound and will stop after about 2 seconds.
5. DO NOT fire the shutter yet.
6. Put the mode on Manual and select a fast shutter speed like 1/90 sec. Any aperture will do.
7. Load the film correctly as given in the user's manual.
8. As you close the camera back, the film will prewind to the end of roll. At the end of the roll pre-wind the LCD will show you the total number of frames available.
9. Select any shooting mode.
10. Go on and take pictures.
