Sorry to read about your problem, I hope this helps you out.
your lite tube may be clogged, or take a needle and clean the hole's next to the lite tube on the range grills.. I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
If you are saying the clicking continues you must move the burner knob past the LITE position. If it continues clicking with the knob past the LITE position the ignitor switch behind the knob is bad.
Sounds to me like you have an igniter that has gone out on you. It's possible that you could have a sensor on your pilot light as well, and actually have a gas issue. Make sure the pilot light is on, and try to localize where the clicking is coming from. You may think it's coming from a certain burner, when in fact, it is coming from somewhere else all together. The ignition source is a pretty easy fix in general, so if you are sure that is where it is coming from, simply go to sears, or any other store that might sell one for your particular brand of stove, and replace it. You'll soon be hearing the sweet sounds of deafening silence. :)
Go to RepairClinic.com and check on how much a new igniter is. Is there two or 4 igniters on your model (lift the top of the range up and it is the little silver piece sticking out with a white base around it), If its 2 is the other side working? Make sure there is no food deposits around where the gas and the spark meet.
it is strange that you have no gas and no spark! if you held a match to the burner and turned the burner valve on it would lite di spite a failed ignitor,but for it not to lite, the burner valve[its what the knob attaches too] would have to be blocked[thats rare]or ........i got it .....the knob is broken.thats the only thing the burner valve and the spark ignitor have in common.try a knob from another burner................again.you have spark,because others are working.spark on troubled burner would work if valve blocked at orifice outlet,and if spark failed you would still get gas they work independent of each other,[but in unison].thats why im thinking knob.its the item that works both .when you turn the knob it opens the gas valve and as the gas valve rotates by turning the knob it activates or turns the spark switch so it closes the curcit allowing the electricty to the spark moduel.hey i hope that helps a little. God bless ,tom
When you set a burner to light, all burners spark. This is normal. Move knob back off the spark position as soon as burner lights. All sparking will stop.
Sounds like the electric sending unit for the right burners is not working. Do you hear the cliking noise on the right side when you turn the knob to LITE? If not then you need to replace the electric sending unit, they are located under the knobs, they are a smal square box that goes on the switch valve rod, they have tow wires on the side, just unplug and lift, and look for greasse or anything that might interrup contact, you might be able to use the same ones, or just replace with new ones....Good Luck
Eddie Rentas
Tupper LAke NY
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
We need a model number. You need a new spark switch.
