Dell Inspiron 1501 Notebook Logo
Posted on Feb 13, 2010
My laptop is dell inspiron 1501 but no work keybord and battery charging but supply line(AC adaptor) is ok.
Anonymous
Level 1:
New Friend:
  • Contributor 25 Answers
  • Posted on Feb 25, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
25
Questions
0
Helped
12869
Points
57
Hello there. The Inspiron 1510 was released almost 5 years ago. If your system is more than 2 years old, then perhaps you will have to replace the battery. Battery for the most part, will only last 1 to 2 years. As for the battery, try connecting an external USB keyboard. If its working, then you need to replace the laptop's keyboard. Hope this will help.
Mel
Hi, I have a Dell Inspiron 1501 laptop, model no. PP23LA. My problem is that the system does not recognise the power adaptor/charger & will not charge the battery. The laptop will run with the power...
If the battery is not charging, the problem is most likely the battery...not the charger. Check around to see if you can get a battery replacement I think would be your best course of action. If you have a friend with a model laptop with the same battery you could always "test out the scenario" before purchasing one.
Good Luck
My 1501 Dell Inspiron wont turn on. The charger
The ac power jack needs to be either resoldered or replaced.
1helpful
2answers
Dell 1501 Error- AC Adapter is not recognized
myabe the battery is faulty have you tried replacing it?
1helpful
Inspiron 1520 Power Fault?
dead motherboard, highly likely to be fine if the battery is full
I have a Dell Studio laptop. Will power on with
This should have a "battery check" button on the battery itself. Remove the battery and press the button. If it reveals that the battery is not fully charged, or you cannot get it to take full charge, perhaps all that you need is a new battery. If the battery is failing the check the system makes on it at boot, it won't.
Dell inspiron 6000 not charging
suspected faulty battery. replace the battery.
1helpful
Can I use ther Targus Adaptor for Inspiron 1525
On the long term, a power adapter with a bigger amperage can damage battery and battery charger.
Better to get an adapter with same specs as the 65/70W one , or an original replacemant:
Dell Inspiron 1525 New AC Power Adapter Supply $14.29 - Buy.com Dell Inspiron 1525 65 Watt Original AC Adapter $25.00 - parts4nb.com Dell Inspiron 1525 Power Cord PA-12 $16.95 - AmeriMax Advance
DELL Inspiron 1525 DC Power Laptop Adapter ... £25.23 - B2C Shopping UK DELL Inspiron 1525 Laptop AC Adapter power adapter £38.99 - Very Good Battery Dell Inspiron 1525 Ac Adapter Charger Power ... £16.50 - eBay UK
AU/NZ - DELL INSPIRON 1505 E1405 E1505 AC Adapter Power Supply
Dell : Lind Electronics 70-Watt DC Power Adapter for Dell Inspiron
7helpful
2answers
Battery cannot be identified Every time I boot up my Dell Inspiron 1501 I get the following message: "Warning: The Battery cannot be identified. This system will be unable to charge this battery."...
Generally this is an indication that the battery has failed. The normal life span of a PC battery is 300 to 500 recharge cycles (Roughly 12 to 18 months) so the most likely answer is buy a new battery since this one is already out of warranty
29helpful
7answers
Replacement battery for Dell Inspiron 1501 won't charge
If your old battery was doing the same (not charging), then is is because the charger is not charging the battery. Do you have a friend with a Dell laptop? Maybe you can use a borrowed charger to test and see if it will charge the batteries. To answer your question , no Dell does not have anything built in to prevent you from using a 3rd party battery.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
