Now this is not quite clear enough to give an accurate single answer.
Is it the fuse within the microwave or the general house supply fuse that blows?
If its the latter then an electrician needs to create a separate fuse line to reduce the overall load on the fuse, 15amps generally. Many houses have too many plugs being used at once on the same circuit TV, dishwasher, fridge/freezer, electric jug etc all drawing power. Big screen Tv's are the worst offenders.
If it is the fuse within the Mwave, then it needs attention,as a short has developed in the unit and needs to be corrected.
I will assume it is less likely to be this and punt for the first solution ( House fuse box overload)
Please rate my help++++Thanks for using FIXYA
