Jet 3 Ultra Power Chair Logo
Posted on Feb 12, 2010
With a full charge chair stops working and won"t power up
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 14, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
403
Points
I have a Jiffy Jet3 . the problem is when I charge the batteries
the light indicator just blinks but chair doesnt run.
I just put new batteries and still doesnt run,,,thanks J.J.F.
My Alante Jr power chair stopped working. when plugged in ,the charger light is green which means a full charge but the led lights all ten of them on arm continuous go from side to side without stopping....
The batteries are too low for the charger to work. You need to take the batteries out and charge them separately with an automotive battery charger. This may take 2 or more days for each battery. When the voltage on the battery gets past 10 volts, you can put them back in the chair and finish the charging with it's charger.
Battery charger on quantum electric wheelchair starts out ember color then starts flashing red I check wires everything is plugged check it about 3 months ago everything was ok now th chair won't
Did you charge it at all during the 3 months? Did you store chair on a full charge? Check to see if batteries are dead. Batteries should be disconnected and/or stored on a full charge. If left connected they should be fully charge every week.
1helpful
Low hour, RASCAL 600 has been in clean safe storage with new batteries won't charge, no amp meter reading, no fuel gauge reading, yet charger itself has red and green light showing. If and when the...
The green light on your charger indicates a full charge but you know thats not right since you didn't charge the batteries when they were in storage they have dropped so low the charger cannot detect them and provide a charge. The batteries will need to be replaced with new ones. Charge before use and charge for at least 20 days to get them operating at 100% now you will have to use it for those 20 days to get the batteries used to charging charge every night when you go to bed and unplug when you get up in the morning. If you do have to leave the chair for a week or so put up fully charged and charge once a week overnight. If you put the chair in storage again disconnect the batteries from the chair and store with a full charge. Hope this helps you
Have a jet 3 power chair will not take a charge, can't tell that iy is charging
Cathey when you plug in the charger look at the rear of the chair at the meter if the chair is charging then the meter will indicate some amperage reading when it is fully charged the meter will read zero. Also turn on the chair and if the lights are scrolling or flashing it shows that the charger is plugged in. Now if after the meter reads zero (if it ever does) the lights on the joystick should all be lit indicating a full charge. If you aren't getting all the lights and the meter indicated the charger was working then you need to replace the batteries Hope this helps
WHEN I TURN THE POWER ON FOR MY JT3 ULTRA POWER CHAIR, THE LIGHTS THAT INDICATE THE STATUS OF BATTERY BLINK ON AND OFF (REGARDLESS OF BEING FULLY CHARGED OR NOT) AND THE CHAIR WILL NOT MOVE. SOMETIMES,...
I would replace the batteries with new ones anyway to make sure that you are getting full power and if the problem stops great if it continues then you have eliminated one possible problem. A low battery will cause the problem and these chairs diagnose themselves with the controller giving you flash codes to indicate a problem. I would just check for a loose connection in the wiring when you have the seat off changing the batteries and give the base a good cleaning( without water) (Use those cleaning wipes from dollar store) Hope this helps you
Shows full charge,goes ok for a little while but then stops turn off then on goes very slow for seconds then stops again.
Hi Susan, I repair power wheel chairs, Its possible that your chair has a bad battery on it , all p/chairs have 2 batteries.And even though you show a full charge one battery may have a bad cell in it you need to get both batteries load tested . I think you my find one of them bad. take them out of chair and have them tested.You can get replacement batteries , and have yours tested at a store that sells batteries only, look in yellow pages for a battery store . Good luck, Erik
Whats wrong ???
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Here's the flash codes for the PG drive on your chair. count the number of flashes between pauses and match it up to see what the fault is.
Chair has no power after a full charge, only allows user to go oneway before it has to be pushed Batteries are good anf fuse has been checked and changed can you help us
Many a times batteries shows you full charged but due to some reason few of the battery plates are not working, and it will only work till the charged plates get discharged.
Batteries plates turns weak or get damaged due to non use of batteries, or expiry.
Top Jet Health & Beauty Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
