Compaq Presario R3000 Notebook Logo
Posted on Feb 12, 2010
Compaq presario r3000 touchpad scroll function not working after allowing remote access to a telecoms analyst to correct a broadband problem. I have reloaded the ALPS touchpad driver from HP. Still no scroll. I have tried changing setting to "look for wheel" & "assume wheel present" but still not working.
brstar
Level 1:
  • Contributor 2 Answers
  • Posted on Nov 28, 2010
brstar
Contributor
Level 1:
Answers
Questions
Helped
5924
Points
5
My R3000 touchpad would not scrolll or allow double-tap. I downloaded the synaptics driver, not the ALPS driver on Compaq's site, and it works perfectly now.
The scroll function on my touchpad no longer works. How can I fix it?
have it replaced. there is no magic fix. Cost about $75.00 for parts plus 1 hour labour so expect about $200
Please rate my help++++Thanks for using FIXYA
Scroll on touchpad not working
Hi! You may access touchpad settings by accessing control panel then go to hardware and devices then click on mouse. It will show a tab that has a drop down option for left and right click functions. Thanks for visiting FixYa.com!
8helpful
2answers
I have a Compaq Presario CQ60 scroll touchpad stop working
The notebook model you have is shipped with the Synaptics touchpad driver. Please follow the below steps to enable scrolling features:
1. Open Control panel -> click on Mouse . It will display Mouse Properties dialog box.
2. Under Mouse properties Window click the Device Settings tab
3. Click on Device Settings -> Settings button. This will display the Properties for Synaptics TouchPad on PS/2 port.
4. Follow the steps below to enable the Tapping Feature :
Highlight Tapping in the Left hand side , and Check the Enable tapping in the Right hand box .
5. Follow the steps below to enable Scroll feature:
Highlight Virtual Scrolling in the Left hand side and Check both the boxes in the right hand side.
6. Click OK .
Alternatively you can anble scrolling by reinstalling touchpad driver.
Touchpad driver for Vista:
ftp://ftp.hp.com/pub/softpaq/sp39501-40000/sp39534.exe
Touchpad driver for Windows 7:
ftp://ftp.hp.com/pub/softpaq/sp44501-45000/sp44940.exe
Touchpad don't work anymore compaq R3000
check the connection or try redownloading the driver for it
2answers
There are two reasons for this, wrong or missing touchpad driver, or scrolling is disabled. First go to HP... http://welcome.hp.com/country/us/en/support.html
put in your exact model number and click on the drivers link, download the touchpad driver and install, scrolling is automatically enabled. When you download a new driver it will over-write the present one and all it's settings.
Touchpad scroll not working
you can order another one online and install it your self but be carefull ground yourself to the metal take out the battery and b on a solid noncarpeted floor and u may use small tools but if under warranty send it in
2helpful
Compaq Presario R3000 dim screen but not dark
Sounds like the auto-dim in the BIOS is set too low. Fortunately the Compaq R3000 allows you to adjust the brightness right from the keyboard. Hold down the [FN] function key while tapping the [F8] key will brighten the screen, while [FN]-[F7] will dim it. The settings are different for running on AC power and battery, so you must do each individually.
Compaq Presario R3000 compatible bios?
I Think the latest bios update for R3000 is F.35. Sounds like you need to reinstall OS or buy a new HD
Cannot use scroll option on touchpad
Have you installed the Drivers for the touchpad in your laptop ? Have a look at this http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&cc=us&dlc=en&product=442914
Download the drivers from here and install them. Should help
-Ranjit
[email protected]
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
