I'm with telstra and used these settings. If you get stuck go to
www.i9forum.co.uk and register then go to the mms & sms section some phone do use a slight variation on this below.
Step 1 – WAP DATA Account Setup
1. Go to the following menu “MENU
> SERVICES > DATA ACCOUNT > GPRS >
Select an empty
Account”
2. Edit the following parameters in the account
a.
Account Name=Telstra WAP GPRS
b. APN=Telstra.internet
c.
User name=[blank]
d. Password=[blank]
e. Auth. Type=Normal
Exit
back to MAIN SCREEN.
Step 2 – WAP Setup
1. Go to the
following menu “MENU > SERVICES > WAP > SETTINGS > EDIT
PROFILE
> SIM 1 or 2 > Select an empty PROFILE > EDIT PROFILE”
2.
EDIT the following parameters in the account
a. Rename
Profile=Telstra WAP
b. Homepage=http://wap.telstra.com/wap
c. Data
Account=Telstra WAP GPRS
d. Connection Type=HTTP
Proxy Address =
010.001.001.181
Proxy Port = 80
e. User Name=[blank]
f.
Password=[blank]
3. BACK then ACTIVATE PROFILE and exit back to the
MAIN SCREEN.
4. Your Phone is ready to access WAP and MMS services.
Step
3 – MMS DATA Account Setup
> SERVICES > DATA ACCOUNT > GPRS > Select
an empty
Account”
a.
Account Name=Telstra MMS GPRS
c.
User name=[blank]
d. Password=[blank]
3.
Exit back to MAIN SCREEN.
Step 4 – MMS Setup
1. Go to the
following menu “MENU > MESSAGES > MMS > MMS SETTINGS >
SERVER
PROFILE > SIM 1 or 2 > Select an empty Account”
2. EDIT the
a. Rename Profile=Telstra MMS
b.
Homepage=http://mmsc.telstra.com:8002
c. Data Account=Telstra MMS
GPRS
Proxy Address = 010.001.001.180
Proxy
Port = 80
f. Password=[blank]
3. BACK
then ACTIVATE PROFILE and exit back to the MAIN SCREEN.
4. Your Phone
You would need to make sure your iPhone settings and your Telstra service is able to do this.
GPRS is the older Telstra network. Next G is Telstras replacement.
I would recommend calling Telstra on 125 111, as all Telstra services are automated, get them to put you through to Technical Support (a person) and enquire how to do it.
Explain that you have searched their website and was unable to resolve the problem (I have done that part for you).
I would suggest if you can, call Telstra from a phone which is different to your iPhone (incase they require you to set up SETTINGS.)
Telstra's settings in your phone can be found
1. Tap Settings on the Home screen.
2. Tap General on the Settings screen.
3. Tap Network on the General screen.
4. Tap Cellular Data Network on the Network screen.
This should tell what Telstra settings are set up for your iPhone. It is also where telstra will ask you to go to.
I use Optus on my iPhone, so mine is slightly different.
I hope this is useful information for you. Please rate. Regards,
I apologize. I misread your phone type. I thought you meant an iPhone not a i9.
However, the Telstra support number will be the 125 111.
The support (help centre) area for Telstra mobiles is :
http://telstra.custhelp.com/app/mobile
You may be able to locate an answer here, else post a question to Telstra.
Regards,
